Question about Kodak EasyShare M1093 IS Digital Camera
I plugged in the charger and after an hour the blinking power button stopped blinking and the camera now does not turn on? M1093 IS camera
    Genius:
  • Kodak Master
  • 1,099 Answers
If the cam. was plugged into the cam and on. Then it doesn't charge it only transferres pics.
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 12, 2009
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
CANT CHARGE KOCASO M9200
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Apr 21, 2014 | Kocaso M766 Dual Core 1.5Ghz Dual Camera...
MY PAD WILL NOT STAY ON AFTER RESET AND POWER ON
Mar 04, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Will not charge
Sounds like you have a bad battery. Check your users manual for how to change it.
May 01, 2017 | Nikon COOLPIX S9500 Digital Camera Black
My samsung phone wont turn on it just blinks red when on charger or power button pressed
Remove the battery for a day, so it will forget its current state. Then put it back in and try again.
Dec 20, 2013 | Televison & Video
Hello, My camera M1093 IS suddenly will open when I hit the power button only to close immediately. The screen comes on for a second and then it closes. I ordered a new battery thinking that may be the...
Could be something stopping the lens to go out all the way. It will automatically retract and turn off if anything prevents it from extending. It could be the motor or whatever but I would definitely contact kodak. Also could be something like a short or software malfunction but it sounds like a problem with the lens not being able to extend fully out.
Jul 30, 2010 | Kodak EasyShare M1093 IS Digital Camera
Kodak digital camera M1093 turns on and then off suddnely
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 17, 2009 | Kodak EasyShare M1093 IS Digital Camera
Camera does not respond when turned on or when plugged in to recharge.
I followed the advice of my Fixya adviser--remove the battery for 3 minutes then plug the USB cable into a different port on my computer and plus in the camera. I did that and turned the camera on as advised but the green light still did not blink. The adviser did not respond when I asked what to do next so I disconnected the camera from the computer and plugged it into the charger. This time the first blue light started blinking (nothing happened when I tried it before following the Fixya advice). I left the camera to charge all night and eventually, after about 12 hours, it did.
Seems O.K. now.
Aug 20, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare M1093 IS Digital Camera Logo
152 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
