Question about Refrigerators
Foul smell coming from the back - Refrigerators
  • 122 Answers
Check for a drain pan full of "foul" water. Also sometimes mice gravitate to the back of the cooler due to the warmth of the compressor. Check for dead mice.
Posted on Nov 13, 2009
How can I fix the foul (like mildew/dirty laundry) smell that comes out of the air vents in my Ford Edge 2015? This only happens when AC is OFF.
Ford are aware of this and should hold there hands up in shame .
thay say it's the catalytic converter causing all these problems . Sorry I can't tell you any more has thay are keeping tight lip about it good luck and don't give in ps tell ford your going to seek legal advice on this matter then see if thay will move on this as bad publicity will make it worse for ford
Jun 20, 2017 | Ford Cars & Trucks
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
2.0 ford engine has new timing belt idles rough but can run smooth while driving has a very foul odor coming from exhaust and has severe blow back when you remove oil filler cap
Sounds like your off timing. Make sure that your timing gears are set on the marks properly. The foul odor your smelling may be because your car is running rich.
Sep 29, 2010 | Ford Escort Cars & Trucks
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
A foul smell in my 1998 Jetta: fear of inernal leak
it sounds like u might have a heater core leak, did they check that? it only takes a tiny bit of coolant evaporating from the heater core to really smell.
Apr 30, 2010 | 1998 Volkswagen Jetta
Foul odor from front load washing machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 06, 2009 | Washing Machines
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Smell with fridge
we had travelled to see grandmother for two days. Apparently my husband switched off the electicity from the mains. Came back found food in the freezer had defrosted meat, fish, liver etc and there was blood in it. i cleaned and all was well. After a week started to notice a foul smell coming from the back of the fridge where the stainless steel is. IT keeps getting bad by the day
HOW DO I GET RID OF THIS SMELL?
Aug 15, 2008 | Refrigerators
2002 New beetle VW
The foul smell is coming from too much eating sweet yum.
Jun 27, 2008 | 2003 Volkswagen New Beetle Convertible
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
