Question about NEC Versa VX Notebook
How to remove NEC C150 hard drive? - NEC Versa VX Notebook
    Master:
  • 969 Answers
    Sergeant:
  • 191 Answers
On the bottom of your laptop you should have square-looking covers with tiny screws in their corners. hdd is under one of those. just powerdown laptop, remove batery, open all covers and then put the non hdd covers back on hope it helped
Posted on Nov 12, 2009
Hdd pasword untuk laptop nec versa
These WEB sites maybe able to remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Nov 09, 2012 | NEC Versa SX Notebook
I have NEC versa S3200.. Was using windows 7...and wanted to turn it back to XP SP3. Formatted the drive and finished installing XP SP3...now it freezes on the NEC screen
Sub out the ram one at a time testing as you go, if that fails you may have a hard drive issue, remove hardware and reseat it back in place, sometimes it will restart, if it does not! try formatting the hard drive again with the XP disc and a re-install, make sure disc is spotless before you start, just might make the difference.
Mar 20, 2012 | NEC Computers & Internet
My nec powermate p3020 is automatically getting shutdown as soon as windows loaded
Hi
Have you tried your hard drive on another machine?Or maybe tried another hard drive on your machine?
Could well be a faulty hard drive.
Also try disconnecting the hard drive and connecting it again.
Feb 28, 2012 | NEC Computers & Internet
Need nec versa e 6000 motherboard faulty . where i can buy the motherboard?
it is not worth it to purchase a new motherboard for around 200$ when you can buy a brand new computer for just a little bit more.
You can have your files moved from the old hard drive to the new laptop by a professional or you can do it yourself if you aren't a complete dummy with computers.
To do it yourself you would need to first remove the old hard drive from the old computer ( NEC ) and then buy a external hard drive case for it that fits to it - there are 2 sizes, 2.5" and 3.5", probably 2.5" hard drive and then there are 2 types of connectors, IDE and SATA. SATA has a flat connector, and IDE has around 40 metal pins sticking out of it.
buy the appropriate USB caseing for it and then connect it to your new computer, you can transfer your files from it to the computer, after you have done so, you can keep the old hard drive as a external hard drive, for backups for example.
Jan 04, 2011 | NEC Computers & Internet
I want to connect this hard drive with other computer. What kind of cable shoud be use for data transfer?
Much better if you buy a usb to sata adaptor, all you have to do is plug the usb adaptor from sata hard disk drive to usb port. It will detect as a removable drive and it is very easy to transfer file. It will serve as a external hard drive. Have a nice day!
Jan 03, 2011 | NEC (OP-220-62006) 1.35 GB Hard Drive
Reset
Just go connect it to your pc.then go to my computer and then right click on the drive which belongs to your sandisk sansa c150(1gb) 2gb mp3 player and select the option format.
Thats all.
May 07, 2009 | SanDisk Sansa c150 MP3 Player
I have an old NEC Versa Premium which is being used as a print server and a backup for storage. It has died. However, the data in the Hard disk is needed. Can any expert teach me how to open up to remove...
Hi
I have the same notebook and I have changed the hard drive on mine as well.It is quite simple really,you will find on the side of the A drive it sits just above it,to remove it there is one screw on the underside if you follow it in line and guess the depth of the A drive you will see it all by itself.
Just unscrew it and slide out the drive.The hard drive is a slim line compartment that sits on top of the A drive.
Just pull it out as it just slots in/out.
Just slot ou new hard drive in screw up the single screw and presto you should have a new hard drive ready to go.
Hope this helps,I have ram probs not sure where to slot the 256MB RAM into,maybe you could help me.
Regards
Iain
Mar 26, 2009 | NEC Versa Premium Notebook
Powermate Eco Hard Drive Crashed
Hello
instructions on how to remove and replace the hard drive are on this PDF document.
http://support.necam.com/mobilesolutions/hardware/Desktops/eco/819-201002-000med.pdf
You will need a pdf reader to open the document, if you are unable to open it download a pdf reader here
http://www.adobe.com/products/reader/
Can you remove the hard drive from the computer, write down the details that read on top of it, and also if you could look at the connectors and tell me the details so I can make sure I direct you at a proper replacement.
Thank you,
Ekse
Feb 03, 2009 | NEC PowerMate eco PC Desktop
Code bios de micro portable nec versa c200
Look for the number of cellular phone secret nec versa c200
Mar 27, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Problems with NEC Versa Drive Case VX MODEL.
Maherani I looked as well if all else fails call NEC support to order the part 1-800-338-9549
Aug 23, 2007 | NEC Versa (808-895500-001A) Drive Case
NEC Versa VX Notebook Logo
220 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
