Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Hi. I have a Bosch 1400 washing machine - it's 3 years old. It has just started not spinning when the drum is full. If I take about half of the wet laundry out it's fine. It doesn't seem to be unbalanced.
  • 909 Answers
What is happening, is your capacitor is faulty. Remove screws holding the lid on to the machine, Lift off lid and with power being off, look for a typical white cylinder that has 2 wires connected to it. On it will read 16micro farad capacitor/ 440vplts etc. Remove it, take it to the parts store and ask for a replacement. Reinstall capacitor and then try running machine on the usual program. If all ok, switch off then replace lid and away you go. Do not continus to run motor as it is now.
Posted on Nov 12, 2009
I have a Bosch Exxcel 7 1400 express, had F21 error which I cleared but now when set to wash, water comes in but the drum doesn't move.
F21 refers to the carbon brushes in the motor so price new brushes - if you are handy they are easy to fit and not expensive - but if you can't do it yourself i personally wouldn't spend too much on repairing a 5 year old machine
May 04, 2014 | Bosch Washing Machines
The washing machine does not spin as good as it did when new. It has gotten where there is still water in the machine after spinning. And clothes are still wet. Last couple of times we had to manual...
My washer does the same thing and it is just a year old. After the cycle is complete I run a spin cycle only at the highest spin level to remove the remaining water. And it works.
Aug 31, 2013 | Bosch Washing Machines
My bosch exclusiv washing machine which is 8 years old has stopped spinning the clothes, they come out soaking wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 26, 2011 | Washing Machines
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 28, 2009 | Bosch Washing Machines
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Bosch Washing machine will not spin
Are you able to see the belt? Maybe it broke. If the drum is not spinning than sometime broke that would make the drum spin. If you machine is a direct drive then there is a problem with the drive shaft.
Jun 01, 2009 | Washing Machines
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
204 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
