Question about Samsung SC-D107 Mini DV Digital Camcorder
Blue screen appears on my samsung camcorder
I have a samsung digital camcorder that gives me a blue screen or a gray black screen that is cloudy and won't focus . model scd107.. any clue what It might be would greatly help.. e-mail ibike4ms@aim.com thanks.. check back with you ....for help...
  • DCconfused Jun 02, 2008
    Same as all above - gray screen with lines when trying to record. Old tapes play well . this seems to be very common - What is Samsung saying fix is?
    Who has the solution...? what good is this web site if it does not lead to a solution????? Fixya? Where is the "Technical Support"????
  • sharliebaksh Oct 31, 2008
    my digital.cam SC-D353 screen shows blurry and records blurry . My old tapes shows perfect
  • 35 Answers
SOUNDS LIKE A BAD CCD.. SAMSUNG IS KNOWN FOR THIS PROBLEM WITH THIS MODEL.. WILL YOUR UNIT RECORD SOUND BUT NO PICTURE? IF IT DOES IT IS THE CCD ..CHARGED COUPLER DEVICE
Posted on Jul 31, 2009
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Shifts between black screen and severely distorted gray images
hi;yes that could be the ccd or a low charge battery
try to charged it for ar least 12 hrs/or its a lens ajustement thats as to be made in a shop because that need special machine like scope and vector scope......
hope that give you an idea about it
truely Alan
May 25, 2010 | Samsung SC-D107 Mini DV Digital Camcorder
Samsung VP D31 stopped recording video - just black screen
my samsung vpd230 has stoped recording, just a black screen,
would you also explain what a ccp is,also the words memory stick keeps keeps appearing.thankyou
Apr 06, 2010 | Samsung VP-D31 Mini DV Digital Camcorder
Black screen
Symptom shows its ccd imager chi failure problem and ccd imager chip will be replaced in your camcorder.
CCD Imager chip is an electronic part that converts an image into electronic signal for further process in camcorder circuit boards.
Take your camcorder to local camera repair shop for ccd imager replacement as it is not user level repair and requires qualified tech.
Mar 19, 2010 | Samsung VP-D34i Mini DV Digital Camcorder
The lcd screen is gray with black bars across it in every mode.
Could be you ccd, charged coupling device, eye of camera. May be pricey to repair. go to panasonic on line for quote
Apr 15, 2009 | Panasonic PV-GS31 Mini DV Digital...
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Phillips cloudy screen
Crt coolant needs changing in the Blue and Gree CRTs red usually isnt affected.
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Camera screen
does the screen isn't working either when you record and when you play tapes? if you record a tape and you play it on another camera, does it look good? if both answers is "yes", chances are screen is faulty. however, if screen doesnt work (remains blue or black) only when playing tapes but functions well while recording, it may be solved by using a cleaning cassette.
Mar 24, 2006 | Samsung SC-D23 Mini DV Digital Camcorder
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Samsung SC-D107 Mini DV Digital Camcorder Logo
134 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
