Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
One in three times fails to empty water - Hotpoint Aquarius WD63 Front Load Washer/Dryer
  • 909 Answers
Remove the drain pump and clear restriction. reassemble and try again. Should do the trick.
Posted on Nov 12, 2009
How i can cleans it
Put three drops of dish soap in it and add water .... put it on the juicer and run for 30 seconds. Empty soapy water add plain water do it again, and just for good luck.... do it one more time to get rid of all the soap.
Oct 20, 2014 | Juicers
How to empty you fresh water tank
There should be three low point drains located under the trailer. Two will be close, side by side, to one another. This is the low point for the entire plumbing system, both cold and hot. There will be another single low point drain which will be for the fresh water tank. The low point drains may only have a cap on them or may have a valve installed.
Mar 08, 2014 | Open Range 2013 Light LT252FLR
I want to descale my capresso 455 with white vinegar, and need instructions
Super easy and have done it for years. When water reservoir is empty fill with a small amount of white vinegar. Then add water until full. Wipe out other parts of machine. You won't want any grounds to hang around. Do not add grounds, but replace basket empty. Allow machine to cycle as if you were making coffee until reservoir is empty. Repeat process with clean water to flush out any leftover vinegar taste. You may have to do it two or three times until the smell is gone. Using distilled water in your machine will keep deposits from forming.
Feb 26, 2014 | Capresso 455 CoffeeTEAM Therm Stainless...
I have replaced this old water heater. But I am not able to get the water out of this water heater. There are some sediments and water it not coming out. How can I empty the water?
I had the same issue a few months ago. To clear the sediment blow back into the hose making sure the valve at the tank is open. I had to blow two or three times during the draining process. 50 gallon tank took about 45 minutes to drain
Dec 09, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Water will not drain after first fill/runs then when it tries to start the drain cycle it just stops and does nothing
This is probably simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the next cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Washing Machines
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Hotpoint aquarius condenser dryer ctd00 - empty water light will not extinguish after water has been emptied resulting in no heat
The float switch within the plastic unit at base of machine has failed,shorted out Carefully prise the unit open Disconnect and identify the three tags Replace switch and attached lever Examine the insulation on the rear tags as they are very close Reinstate Red light will now extinguish pump will run when float operates hearers will come on
Oct 15, 2009 | Hotpoint Dryers
Error message states no water, but there is...
Unplug the device and plug back in after 1 min. If it still fails, then you have a dirty water level sensor or the control circuit board is fried. Empty the water out and fill it with vinegar as full as you can without overflowing. Let it soak overnight and turn the machine on (without coffee in it). Turn off after 30 secs.Turn on again and allow it to finish the cycle.  Discard the vinegar. Run three more brewing cycles with water only and it will be OK to use. If this does not cure it, then the only cost effective way is to replace it.
Apr 26, 2009 | Krups FME2 Coffee Maker
Will Wash, but not discharge water nor spin.
the lid switch is broken PLEASE rate my help!! Thankx
Oct 03, 2007 | Whirlpool LXR5432KQ Top Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
