Question about Canon Rebel XT / EOS 350D Digital Camera
I receive error 05, it makes a few clicks then error message apears asking me to restart the camera. This i have done many times without success. It is a new camera and has not been dropped
  • 477 Answers
Error 05 is a flash popup error. the pop up silonoid is acting up or being blocked. we fix this all the time
Posted on Nov 13, 2009
Lens error. Restart camera
Lens unit is faulty is not zooming or working properly that why you getting lens error.
you can try to open camera and near lens unit you can blow with pump to remove any dust is not causing this problem if work then good other wise you need replace len unit
Jul 03, 2010 | Canon IXUS 80 IS Digital Camera
Access Probelm with DSC-W50 camera
abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
May 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
My live messenger
Here are suggestions from the Microsoft WLM group: Clear the SSL Cache:
Start Microsoft Internet Explorer.
On the Tools menu, click Internet Options, and then click the Content tab.
Under Certificates, click Clear SSL State.
When you receive the message that states that the SSL cache was cleared successfully, click OK.
Clear the temporary Internet Files:
On the Tools menu, click Internet Options, and then click the General tab.
Under "Temporary Internet Files", click on "Delete Files".
Check "Delete Offline content" and click on OK twice.
Reregister SSL security libraries. To do this, click Start, click Run, and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command:
REGSVR32 softpub.dll
REGSVR32 wintrust.dll
REGSVR32 initpki.dll
REGSVR32 Rsaenh.dll
REGSVR32 Mssip32.dll
REGSVR32 Cryptdlg.dll
REGSVR32 Dssenh.dll
REGSVR32 Gpkcsp.dll
REGSVR32 Slbcsp.dll
REGSVR32 Sccbase.dll
Remove all Microsoft related entries from the "Untrusted Publishers" list.
Open Internet Explorer.
Click on the Tools menu followed by Internet Options.
Go to Content tab.
Choose Certificates.
Go to Untrusted Publishers tab.
Delete all the entries in Untrusted Publishers that have Microsoft Corporation under the "Issued to" list.
Adjust your Microsoft Internet Explorer security settings:
Start Internet Explorer.
On the Tools menu, click Internet Options, and then click the Advanced tab.
In the Security section, make sure that all the following check boxes are selected:
Clear the Check for server certificate revocation check box.
Use SSL 2.0
Use SSL 3.0
Verify the date and time settings on your computer:
Click Start, click Run and type in control timedate.cpl and hit ENTER.
Verify that the date and time settings are set correctly.
Clear the entry in the Hosts file:
Click Start, click Run and type %windir%\system32\drivers\etc and hit ENTER.
In the Microsoft Windows Explorer folder window that opens, look for the Hosts file.
Right-click the Hosts file, click Open with, and then click Notepad.
Delete any entries that relate to the passport.com domain, such as Loginnet.passport.com, LoginMSNIA.passport.com, or Login.passport.com, passport.net
Save and then close the Hosts file.
Clear the DNS cache:
Click Start, click Run, type cmd, and then click OK.
At the command prompt, type ipconfig /flushdns, and then press ENTER. This command flushes all the DNS entries that have been cached.
Restart the computer and try to sign into Messenger again.
If you are running a firewall, and if the computer is running third-party (non-Microsoft) software or firewall software, such as ZoneAlarm, Norton Internet Security, or McAfee, make sure that the software is set to let Windows Live Messenger operate, and then try to sign in to MSN Messenger again.
This was not my solution credit goes to the Microsoft WLM group
-Blazamane
Dec 13, 2008 | Microsoft Windows XP Professional for PC
I receive ''access'' error
The "Access" will stay there until your camera passes it's self lens test. The test runs 3 times, then gives up with an error message. The cause of this problem is most likely a grain of sand somewhere in the lens. Only a camera tech could possibly ever hope to find it. Replace the camera lens.
Nov 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
I have a canon 400d eos digital camara, and when i try to use an error message is displayed error 05 the built in flashes auto pop up was obstructed i have attempted to turn off and on without success...
There is a little switch that tells the camera if the flash is up or down. if your flash is up and you get this message then the switch is eather damaged, a tab is broke or the mainboard is acting up. Thing are a pain let me know if I can help you any further. Hope this helps
Jul 03, 2008 | Canon Cameras
well well well a simple way to fix it if u r scraed to whack thn tap the lens,menu part ,sides wid a pensil or a pen...bit little harder atlest d cam should get little vibrations well it really works...belive even i had d same problem just after 15days just d previos day to a holiday...thn i just tapped itwid ma fingure n u wont belive it worked...
Feb 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
The soluction not working
Tap side of camera with base of hand with 2 or 3 sharp taps.  Then turn camera on.  Problem should be solved.
Oct 18, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
This soluction not working
Hi REYPERLA
I`m afraid resetting the camera will not work. The camera has a lens problem and is therefore giving the error.
Contacting your nearest Sony service centre is your only solution.
Sorry about the bad news : (
Dawiem
Canon Rebel XT / EOS 350D Digital Camera Logo
581 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
