Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Boss My counter top Jenn-Air with oven will only slightly warn. There is 240 V at range connection. ther is 120 at range top plugins
  • 26 Answers
If the top units and oven only get barely warm you have a loose connection on one leg of the 240 volt maybe where the line enters range.
Posted on Jan 09, 2008
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Appears wall oven not getting power.
First thing I would check is the household breaker...if it is good, go to the back of the unit where the power cord hooks up to (the terminal block) and check each side for the appropriate voltage. Should have at least 120 volts from black to center (white), 120 volts from red to center and 240 volts from red to black. If you have all of the appropriate voltages, then you need to concentrate on the control boards. Good luck
Jan 31, 2013 | Jenn-Air Kitchen Ranges
Jenn air mod. # sve47100 oven not heating
when you checked the elements for continuity did you remove at least one of the wires off of it,if not it will check good.if the elements are good,unplug it,pull it out and remove the back wall so you can get at the wires,plug it back in and make sure you're getting 240 volts to the bake element and 120 volts to the broil,if you have 240 volts coming to the machine at the plug and you don't have 240 at the bake element check for broken wire,if wires are good you have a bad clock assy. the relay on the computer board is bad and you'll have to change out the clock assy. unfortunitly you can't get this clock anymore but you can send it out to have it rebuilt,go here and get info,hope this helps
http://www.repairclinic.com/PartDetail/Oven-Control-Board/71002331/695629
Dec 12, 2012 | Jenn-Air SVE47100 Slide-In Electric...
120v on bake element red wire and element wont heat up
the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
Oct 27, 2012 | Jenn-Air JMW8530C Electric Double Oven
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i...
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air electric down draft stove has power to the controlls but the power to the elements is not working on the stove and the oven. is there a fuse? What is my problem?
The electrical connections are as follows: L1 goes to one of the 120 VAC hot lines. N goes to neutral. L2 goes to the other 120 VAC hot line. You may have a separate ground wire (required on all new installations) connected to the stove frame. L1 + L2 = 240 VAC.
Your controls are connected to L1 and neutral. The wiring here is good. The heater elements are connected to L1 and L2 with no connection to neutral. Either the L2 line is open, or the L1 connection that provides power to the heaters is open (probably a different wire than the one providing power to the controls). L2 is the most probable culprit, and the problem could be the wall socket, the stove cord, or a bad connection inside the stove. (I recently fixed a case like this - both the socket and the plug on the cord were burned out.)
Jan 14, 2011 | Jenn-Air JES9800A Electric Kitchen Range
Jenn air oven will not heat you push bake and it says 100 but never heats up
One side of your 240 volt connection is disconnected, most likely in the plug wire connection. The neutral and one leg of your 240 is working thereby your display still works since it runs of 120 volts. Happened to me I had one wire come loose from stress on the plug
Sep 19, 2010 | Jenn-Air JJW8530C Expressions Collection...
Oven only heats to 150 f regardless what the
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 16, 2010 | Jenn-Air JES8850AAS Electric Kitchen Range
Jenn Air Older Oven wall unit only
Shannbooks The first thing I would recommend to do is to reset the power. Turn off the breaker for the range for couple minutes and then turn it on. In the most cases it works. Set the time of the day and try to use the oven. If it would not solve the problem let me know. Good luck. Gendos. post back...
Jul 08, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
87 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
