Question about Intel PRO/Wireless 2200BG 802.11g/b
How can i recover file deleted in error - Intel PRO/Wireless 2200BG 802.11g/b
  • 102 Answers
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted files is to try some file recovery software. Recommended asoftech data recovery as it saved my life many times. download asoftech data recovery from
http://www.asoftech.com/adr/
here's a video tutorial shows how to recover deleted files
Posted on Dec 19, 2012
    Scholar:
  • 37 Answers
Firstly,go to recycle bin.If your book there,right click the book and select 'Restore'.
Can't find it in the recycle bin?Don't worry!Files you deleted from recycle bin were not erased permanently.They are just inaccessible or invisible.The space your deleted files located on is marked as free space that can be occupied or taken by new data.Therefore,you can recover deleted files in Windows from emptied recycle bin with data recovery software.Tenorshare data recovery can recover data after deeply scanning your hard drive to look for lost data you accidentally deleted. By the way,you can download it and scan your hard drive for free to preview whether your deleted files can be recovered. Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Posted on Sep 05, 2011
  • Nick Cannon May 31, 2012
    Thanks you, Ivan. Your solution helped me.
Hetman File Recovery - the powerful program for restoration of data, which disappeared from your hard drive. Hetman File Recovery automatically finds information media even if on them Boot Sector or the file allocation table FAT (this option was remote or damaged doesn't work in NTFS systems). The program is developed for restoration of the damaged files. Hetman File Repair recovers ("corrects") the files damaged by abortive attempt of restoration, virus attack, antivirus treatment, failure of power supply, program or hardware.
how can i recover file deleted in error - f9dac679-2a2a-47fa-9f42-613528c6031f.jpg
Some main possibilities of Hetman File Recovery: supports file systems of FAT 12/16/32 and NTFS; supports IDE and SATA-HDD, USB flash, Memory Stick; supports formats: ARJ, AVI, BMP, CDR, DOC, DXF, DBF, XLS, EXE, GIF, HLP, HTML, HTM, JPG, LZH, MID, MOV, MP3, PDF, PNG, RTF, TAR, TIF, WAV; allows to save regenerated files on network drives; unique feature of Special Recovery: restoration of files on which there is no link from the directory; works with ZIP archives; recovers files with the initial time and date; supports operation with network drives. You can view disk contents, as in the standard conductor of MS Windows. It allows you to find and recover the necessary files easily. The preview feature built in the program, allows to see the corrected file before saving. Thanks to it, the product is very easy to use and available to any user - both experimental, and to the beginner.
Official site of the program:http://hetmanrecovery.com
Posted on Jul 23, 2013
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 38 Answers
Lost your files on Android phone & need to recover deleted videos,audios,photos? try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted videos. videos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted videos before recovery. Watch the video tutorial to learn how to retrieve videos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve videos lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
Posted on Jan 11, 2017
    Problem Solver:
  • 5 Answers
UFlysoft Data Recovery - Help to Recover Files from Emptied Mac Trash!
Up to 95% of lost files can be recovered even after emptying Mac Trash. Recover files on Mac Perhaps you've ever met this situation: you thought the files were useless or the files took up a large amount of Mac hard disk space so you removed them to the Mac Trash. But one day you suddenly realize actually one of the deleted files is important and you need it right now. What will you do? First thing first you may go to check the Mac Trash, if lucky enough you can get it back from the Trash, but what if theTrash Bin has been emptied? Take it easy, solutions are more than problems! To recover your lost files, uFlysoft Mac data rescue software uses several powerful techniques for getting back lost files. The choice of which one to use is made easy - just few clicks of the "Scan" and "Recover" buttons, the software will run through all of the recovery options, one by one.
Posted on Dec 04, 2015
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 24 Answers
The files deleted by error can be recovered before new datas have been written on the occupied space.
Here is a guide about how to recover lost folders from hard drive, by following it, you can also recover other files such as images, documents, videos and etc.
Posted on Aug 14, 2013
    Problem Solver:
  • 5 Answers
Have you checked the "Recycle Bin?"
Actually, after deleting some files on a computer, the deleted files are not wiped out completely. They are only moved to a folder named "Recycle Bin" and would wait here till anything new was moved here to occupy their space. That's why one can restore his deleted files back before they are overwritten.
Therefore, if you have no any data backup, you also could try to restore these deleted files for free by using a file data recovery freeware named iCare Data Recovery Free. This data recovery freeware has helped retrieve my inaccessible files many times. It has never let me down.
Note: Do not save the restored files on the same drive in case of data recovery failure.
Do not forget to back up everything important on different drives, not only on one.
Posted on Jul 26, 2013
I think the best way to recover lost files is to use data recovery software. You may download one from here: http://www.idisksoft.com
Posted on Feb 26, 2013
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Hello, smmch982. You can recover your lost files with data recovery software:
Data Recovery for Windows
Data Recovery for Mac
Best wishes!
Posted on Feb 13, 2012
  • 18 Answers
If you are running a Mac. Data Recovery for Mac is just needed, which enable you to recover lost/deleted/formatted files,even after you emptied Trash bin. Details in http://www.uflysoft.com/data-recovery-mac/
Posted on Dec 20, 2011
MS Outlook Recovery
Please try:
Outlook recovery set program serves for fixing email threats against any damage, caused by file system errors, disk issues and other problems, corrupting the structure of OST and PST files.
For more information: https://www.outlookrecoverykit.com/
Feb 12, 2015 | Microsoft Office Outlook 2007: Windows
Tip
How to Recover Deleted Files Have you accidentally deleted your files from...
Have you accidentally deleted your files from the Hard disk? Do you desperately want to recover them back? Well you need not panic! It is possible to recover the deleted files back from your hard disk (even after you have Shift+Deleted) provided you act as soon as you realize that your files are deleted and use the best deleted files recovery software. In this post you will find a detailed information on how to recover the deleted files from your Windows PC or Mac. Today there exists hundreds of data recovery tools and softwares on the market which boast to recover 100% of all the deleted files back in the original condition. But in reality most of these softwares are neither effective nor capable of recovering your files back. So it is very much necessary to make the right choice of the file recovery software in order to recover deleted files back in the original condition. We recommend the following softwares to recover the deleted files
1. Stellar Phoenix Data Recovery (for Windows)
2. Stellar Phoenix Mac Data Recovery (for Mac)
Stellar Phoenix is one of the best company specializing in deleted files recovery services and solutions since 1993. Stellar’s Data Recovery Solutions encompasses a wide range of software for almost any data loss situation ranging from accidental formats to virus attacks to software malfunctions. Hence Stellar provides the best tools to recover deleted files with over 1,000,000 satisfied customers across 137 countries.
How the File Deletion Process Works?
When you delete a file from your computer (or even from the recycle bin) the file is not actually deleted. Unlike what most people think, the file is not permanantly deleted or dropped from your hard disk. Let’s take an example of a book containing 50 pages. Suppose when you delete the page 25, assume that only the entry in the index which points to the page 25 is deleted and not actually the page 25 itself. Likewise when you delete a file from your hard disk, only the pointer which points to this file is removed and not actually the file itself. This file still exists intact and is 100% possible to recover it back in the original condition. In this condition the file becomes invisible and hence appears to have deleted.
What are the Chances of Recovering my Files Back?
Since the operating system doesn’t immediately re-use the space from the deleted files, it is most certainly possible to recover the deleted files back in 100% original condition. It may take up a very long time for those files to be completely deleted since the modern hard disks have ample capacity. Hence the chances are too less that the space from the deleted files are re-used immediately. So, it is really worth to try out the file recovery softwares like Stellar Data Recovery for Windows or Stellar Data Recover for Mac. Some files are reported to have recovered even after years of it’s deletion. However for the best results, it is recommended that you use the file recovery software as immediately as possible to recover your files.
Recovering the Deleted Files
In order to recover the deleted files all you need to do is perform a scan (search) for the deleted files using a File Recovery Software. Please be informed that there is no manual way to recover the deleted files. The Phoenix Data Recovery software performs a thorough scanning of the hard disk sector by sector and will locate the existence of deleted files to restore them back in the original condition. It is the only software that supports 185 popular file types including Windows NT Registry, JPEG, MP4, GIF, BMP and MS Word files. The software offers rich graphical support and incorporates advanced scanning methods to completely scan and recover deleted files from your hard drive. With this you can
  • Recover FAT16, FAT32, VFAT, NTFS, and NTFS5 file system partitions
  • Recover deleted emails
  • Recover deleted documents
  • Recover deleted photos
  • Recover deleted music
  • Formatted Hard-Drive recovery
  • Recover files from USB Drives, CDs, DVDs and memory cards
  • Recover almost all the camera format files
Visit the following links for more information on Stellar Data Recovery
free software to recover data
1:Recuva
2:Pc file recovery
please rate the artical
on Mar 30, 2010 | Computers & Internet
How to recover emails of Exchange Server?
This utility easily solves all type of corruption issues of exchange files. For more information and free download click here:- Exchange Server Recovery
Jun 05, 2014 | Computers & Internet
Missing data files from MS windows 8
try this see if this works
CRAY SX 6 Data recovery with Recuva it might help u. i have been using this for a long time
May 07, 2014 | Computers & Internet
Is there any possibilities to recover the deleted files on the recycle bin after empty the recycle bin? What is the solution?
Yes, it is technically possible to recover any deleted file (Even those removed from the Recycle Bin) by using recovery software.
Check out how to recover deleted files from recycle bin from link blow.
http://www.asoftech.com/articles/how-to-recover-files-deleted-from-recycle-bin.html
Jul 02, 2011 | HP Computers & Internet
How to recover deleted mails in the outlook express 6.0
A damaged DBX file of Outlook Express can be repaired with an professional application to Outlook Express . By using this utility, you can repair and recover deleted emails or damaged DBX file without any difficulty.
Try:- Outlook Express Recovery Tool
Feb 11, 2008 | Computers & Internet
Intel PRO/Wireless 2200BG 802.11g/b Logo
2,226 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
