Question about Samsung Digimax S730 Digital Camera
Samsung S730 My Samsung Camera won't turn on and the lens is stuck out it won't go bacck in I've tried changing to alkaline batteries and the new pix batteries but can't get any response what's going on? WHat do I do?
  • 13 more comments
  • touterse Jan 16, 2008
    My s73 lens is stuck out and will power on but it will not retract. It does move some when turned on or off but does not seem to focus. It has worked fine for all of 3 weeks. Removing the batteries did not work.
  • Anonymous Mar 13, 2008
    same thing...stuck lens....this is shitty.
  • gabecrz Oct 14, 2008
    my lens is stuck out and it flashes an orange light and does not power on what do i do
  • Anonymous Oct 16, 2008
    my lens won't go back in and the power does not turn on. i bought a new set of batteries and tried to turn the power on but it blinked for a few seconds without turning on.
  • Anonymous Oct 19, 2008
    Hi here,I have the same problem and I need help.
  • Anonymous Oct 27, 2008
    Camera will not turn on
  • h_o_n_e_y_7_ Oct 30, 2008
    I have tried several different brand new sets of batteries but my camera still won't power on and the lense is stuck out. Sometimes the green power light will flash for a second or two but nothing happens.
  • catratcho Nov 02, 2008
    TOOK SOME PICS....EVERTHING FINE......THEN CAMERA SHUT OFF, LENS STAYED OUT....CHANGED BATTERIES, BUT NO LUCK. CAMERA BEEN THIS WAY EVER SINCE....REAL BUMMER.
  • nowaymegana Nov 05, 2008
    My camera has the lens stuck out and when i try to turn it on the screen just says SAMSUNG forever untill i take the batteries out.
  • Anonymous Nov 16, 2008
    So do I. I've tried changing them. Doesn't work. D:
  • siahny Nov 27, 2008
    I have the same problem and it has not been damaged. Any answers?
  • luckyone456 Nov 29, 2008
    I have a samsung s73 I got as a gift. It has not sustained any damage. The lense is stuck out and will not go back in. When I turn it on it just beeps three times as it tries to pull the lens in then shuts off. This is the second one I had that crapped out so fast and had lense problems. Not worth fixing...guess I should buy a different brand!
  • Anonymous May 03, 2009
    My camera did get dropped on the lense while out. seems jammed. any way to unjam?
  • Anonymous May 23, 2009
    wow, these things must be pieces of junk cuz I have the same problem
  • Anonymous May 25, 2009
    I think the best thing to do is to send it back
HOW DO I TRANFER PICS FROM THE CAMARA TO MY COMPTER
Posted on Oct 24, 2008
It doesn't work. I've tried. I'm having the exact same problem! these cameras ****!
Posted on Oct 17, 2008
If the lens is physically stuck, as in not moving in or out, this is a lens problem. Removing the batteries won't change it. Possible drop/impact damage, sand damage, did the camera get bumped or pressed on and try to turn on while in it's case?
Posted on Oct 21, 2008
  • 75 Answers
Try to remove your batteries for a minute and then reattach them again.
Posted on Jan 14, 2008
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 28, 2010 | Samsung Digimax S730 Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
CAMERA MAKES THREE BEEPS AND THEN TURNS OFF LENS WONT RETRACT
Try lithium ion or rechargable batteries (maH > 2500). Alkalines (regular duracell/energizer) have trouble powering many digital cameras since they cannot sustain the amount power output necessary.
Jul 27, 2009 | Samsung Digimax S730 Digital Camera
Samsung S1065 does not turn on, beeps 3 times before powering off. Lens is extended, have checked batteries, not sure what else to do??
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
Oct 01, 2008 | Gateway DC-M40 Digital Camera
I have the Nikon Cool Pix 5.0 Megapixel Camera
try rechargeable batteries, don't know why, but they work better than alkalines and are recommended for cameras :)
May 20, 2008 | Nikon COOLPIX L10 Digital Camera
Already frustrated wit samsung S73
Make sure you are using alkaline batteries.
I agree the battery use an ugly problem. Mine does the same. It's either a design flaw or really bad quality control.
Feb 10, 2008 | Samsung Digimax S730 Digital Camera
Sam sung Camera won't turn on
Try to power reset your camera by removing the batteries for a minute and reattach them again.
Use lithium batteries.
If that doesnt work, consider sending your camera for service.
Jan 14, 2008 | Samsung Digimax S730 Digital Camera
Won't turn on
I had something similar happen after five minutes. The included batteries are crap, try some rechargeables or brand new alkaline. Be warned this camera likes to eat alkalines but does well with nimh.
Sep 02, 2007 | Samsung Digimax S730 Digital Camera
Samsung Digimax S730 Digital Camera Logo
355 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
