Question about Nokia 6600
Phone power failure - Nokia 6600
Module making noise after power failure
If the batteries are old, there could be a problem recharging them after a power failure. This can cause such problems
Apr 07, 2014 | Inter-Tel EncoreCX Voice Mail Module Phone
Mms failure on iphone 3g. when trying to send picture msg is doesnt complete the looad up and says failure.
Did you just try to restart your iphone by turning it off like this:hold on the home button and the power button,until "slide to power off" appear and then slide to power off.
then turn it on, and try again to send your pic.is it working ?
Sep 25, 2011 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
Display light no work
Possible failure of the back light LED in the panel , it can be due to open circuit in the board due to corrosion , it can be a frack failure or a failure of the LED power.
Remove the front panel and use a good observation lens/lamp to check for the circuit. Trace and confirm the line break so as to loop the broken lead. If not there is problem in the motherboard circuit.
Sep 20, 2011 | Nokia 3110 Cellular Phone
We had a power outage, main system box making sound like a rotary phone when I dial.
The battery in your phone system is dead. This will happen every time you have a power failure. Everything resets. Date becomes Jan 1st 1980 (but might update if you have callerID), all phones will have access to only line 1 and line 2, both those lines will ring on all calls, and the line settings are set back to pulse ...
Ideally you either have the battery replaced (it's soldered on the board of the system), or you get a new phone system. Otherwise you'll have to reprogram everything when you have a power failure.
Jason the phone guy
May 10, 2011 | Nortel Meridian M7208 Corded Phone
Power failure
This may sound silly, but is it a cordless phone?
Is the plug securely in the wall...?
Happened to me...felt silly ...
Apr 26, 2009 | Lands Phones
Sony ericsson v640i just went dead
it may be due to
1.battery failure
2. software failure
or an power related problem
Jan 16, 2009 | Sony Ericsson V640i Cellular Phone
Bluetooth failure
You may need to have the firmware reflash back into the phone to have your BT working again...take the phone to a mobile service center to have this done.
Sep 01, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Power failure message.
Power Failure Recovery
If the system is disconnected from the AC power it will not operate. Your announcemen and messages are retained in memory during a power failure but you will need to reset the clock. See the instructions on the bottom of the unit. If the message window displays CL, you need to reset the clock. See the instruction on the bottom of the unit.
Mar 11, 2008 | AT&T 1726 Digital Answering Machine
How to reset phone when flashing CL after power failure
All you have to do is reset the date and time and youre good.
Nov 15, 2007 | GE 21028GE3 Cordless Phone
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
