Question about Dell Inspiron 6000 Notebook
HardDrive(ata100),Will only run at(ata33)! How to fix?or Correct?
I have just bought a Dell inspiron 6000,from a friend. Its harddrive is 40gig,& meant to be ata100(udma5)capable, though when I did a clean re-install of XPproSP3,& checked the device Manager,its driver says it cld only get it to run in udma2,(ata33) I have updated drivers, though still at udma2! Why? & how do I fix this annoying & performance sapping problem? Any advice on this, wld be very much apprieciated! thanx. Gwarpta
  • 380 Answers
Check the BIOS settings. The bios is the operating system for the core hardware, and windows follows the bios directions for hardware. Something you might want to look for is bus frequency, and any hard drive compatibility settings.
Posted on Nov 12, 2009
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Dec 19, 2012 | Dell Inspiron 6000 Notebook
Remove hard drive from dell
Going with Dell Inspiron i1200 series of Notebook PC;
Dell Support > Inspiron i1200 and i2200 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Left-click on Harddrive in the list.
BEFORE removing Harddrive;
Remove ALL power. Remove the AC adapter (Charger) and Battery.
Why are you removing the harddrive, may I ask?
Post back in a Comment.
Regards,
joecoolvette
Apr 29, 2012 | Dell Inspiron 1200 Notebook
Is a 320gb HD compatible with the Inspiron Dell laptop?
Hi, I think its compatible with Dell Inspiron as long as the 320GB uses the same cable like IDE or SATA with that dell inspiron, and I think if ever your machine right now uses on the IDE cable it can still handel a 320GB capacity because an IDE cable can accomodate up to 500GB size Harddrive. Also I would suggest that if this would work on your machine try partioning your 320GB to one 60GB for your operating system and the other space is for your data storage. Hope this helps
Jun 03, 2010 | Dell Inspiron 6000 Notebook
Dell Latitude wil a DST short test fail. error
you are correct, time to replace the hard disk drive.
Jan 28, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 530 was set up two days ago and worked fine until I tried using it this evening. The fan is running and nothing happens when I click the mouse.
For that open cpu cabinet.
Refix RAM memory.Reattch both connection to harddrive.
Then when you power up the computer press F8 key then enter in safe mode.
Then go to start menu->run or press windows key + R key so you can see run type in run "chkdsk /r" then press "y" then restart computer then it fix errors on harddrive.
Also scan your computer with updated antivirus.
Let me know if you need further assistance.
Thanks for using fixya.
Jan 19, 2010 | Dell Inspiron 530s Desktop Computer...
Blue screen on Dell Inspiron 6000 Laptop
OUCH... Might need a new harddrive or motherboard. Does it even let you go into the bios? Maybe you can do a full reinstall to save you the dough.
Jan 06, 2010 | Dell INSPIRON 6000 CENTRINO...
I have the same problem
that is under warrantee. bring to warrantee much better they responsible to fix that if can't fix they will change for you the new items.. better for you
that is hard ware problem i mean board....need to open the board then check... but its under warrantee don't open it....
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 laptop won't boot up
Pleae reboot your system and when you see the Dell logo , press the F12 key a couple of times .
In the menu, select only HDD diagnostics and post the results back . If the harddrive fails, then the only solution would be to replace the same. If the hardrive passes , we may be able tp fix the system
Thanks
proton
May 31, 2009 | Dell Inspiron 6000 Notebook
My computer is running slow.
hi , the slower of the pc has many causes , could be hardware or software issue, after you upgrade the meomory and you still face this problem, so the only issue it seems now is the harddrive, try first to format the harddrive this could fix the problem since most of freezinf issure caused by softwares installed in the hard drive, if you donot want to format it, there is alot of progams can help you check your harddrive and fix the problems. let me know if i can help you in anything else, thanks for joining fixya.com.
Mar 01, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 6000 Notebook Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
