Question about Dell Inspiron 9300 Notebook
When i switch on vertical lines all over screen moving lines horizontally last night eventually settled and picture fine. this am no such luck any tips
  • 54 Answers
Sounds like a video issue. Try plugging in an external monitor and see if you get the same results. If you do then the video card or motherboard in the laptop is going out. If the external display looks find then its your laptop lcd.
Posted on Nov 12, 2009
    Sergeant:
  • 199 Answers
Hello !
This problem can be brought about by less volage going to the LCD or having faulty flat cable ( broken) so you need to check this lcd cable if fine.
get another LCD ie just to confirm the state of your LCD I mean swap it beacuse the LCD could be damaged during drops .
Last but not list get your multimeter get the voltage readings going to the LCD.
Check if the lcd cable is seated correctly on its slot
Good luck
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Screen doesnt work, sound works fine. It worked fine last night but wouldnt turn on this morning, why?
is the screen dark?, if is it, see if the TRC filament is light, if is it afirmative, turn a little clockwise the fly back knob that say SCREEN and watch if there is a horizontal line at midle of the tv screen. if is it, your problem is in the vertical stage.
Apr 10, 2010 | Sylvania 6427GG 27" TV
The tv screen is moving really fast
This is your VSync. On older TVs, there is a dial you can adjust to hold the image in place. Do this only if all channels are appearing with the same vertical movement.
Nov 27, 2008 | Televison & Video
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
New LCD TV Not Working!
dear one
your this probleam is with inerface card which built in tv .so called your service pepole and ask him to reinstalled the input interface card again. if you not taken it seriously it may a big problem for your tv in futre so just take an a action
Jan 24, 2008 | Televison & Video
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Dell Inspiron 9300 Notebook Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
