Question about LG KG290 Cellular Phone
Beeps made as text is written. Accessing new T9 words
1) how do I disable the beeping noise made for each letter as I am writing a text message? 2) Having made numerous new T9 words and saved them, I can't find any info on how to access them.
    Sergeant:
  • 199 Answers
Hello there !
You have to go to phone settings choose tones look for key pad tone setup select it then dactivate it then save settings .
Good luck
Posted on Nov 12, 2009
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Daughter borrowed phone and switched the text msg typing to auto fill and numbers. I have tried every thing and I can't figure it out, can you please help me? Thank you, Susan
Based on your description, what you are referring to is called T9 Predictive Texting. It allows words to be entered by a single keypress for each letter, as opposed to the multi-tap approach used in the older generation of mobile phones in which several letters are associated with each key, and selecting one letter often requires multiple keypresses. Example, when typing the word 'love' in a T9 activated phone, all you have to do is press the numbers 5, 6, 8 and 3 once in sequence. As compared to the regular texting, in order to complete the word 'love', you have to press the number 5 thrice, the number 6 thrice, the number 8 thrice, and the number 3 twice.
If you want to disable T9 predictive texting, it can usually be disabled by pressing and holding the hash or number key (#).
Hope this information is helpful.
Apr 08, 2011 | LG Cell Phones
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
How do I delete auto text words from dictionery Samsung GT 8300
No, u cannot delete the auto text word from the build-in dictionary function name T9, but u can disable this auto text mode.
When open a new text message, just press the icon ABC to change the mode to ABC, T9 or number.
YBC (/\)
Oct 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
When I am writing a text message the phone starts predicting words. I just want to send a simple email without any ''help''
Hi!
If you are seeing the T9 icon on your screen, this is the T9 Text input feature of your phone. It act's like a built-in dictionary for commonly used in a sentence.
To disable this, while on writing mode, press and hold * key to disable text input.
Sep 25, 2009 | Sony Ericsson K850i Mobile Phone
When I start to type a words automatic words come up
I assume you mean when you are writing a text that this happens?
This is predictive text (t9),where the phone automatically tries to predict the word which it thinks you intend to type,
It has its advantages in that it can make typing a text faster but it does take a while to get used to and some people just prefer to text by the method they are already used to,
You can disable the predictive text if you wish and use normal text for your letter input,the option will be on your phone in the settings,if you are unable to locate the option reply back with your make/model of handset and I will tell you how to disable it
Sep 07, 2009 | Lands Phones
Text message function seems to be in some automatic word mode.
hi you are using the T9 dictionary on your phone to change settingsfollow these steps
1. go to messages
2. create new message
mow on the top left u will see a prcil with2 lies and abc written this means u are using the automatic dictionary function to change it press # button till u only see apencil and abc and no lines
now u can manually type words.
Dec 28, 2008 | Nokia 2610 Cellular Phone
Problems with T9 predictive text Samsung SPH-m530
the phone is most likely got the setting only suggest alternate words after the 3rd letter inputted (unless i misunderstood the phone that setting's meaning)
Dec 08, 2008 | Samsung SPH-M500 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
LG KG290 Cellular Phone Logo
50 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
