Question about Remote Controls
Need a code for a coolsat 6000 sat receiver
Have a coolsat 6000 sat receiver and i had bought a nexxtech 4 in 1 remote and it seems not to reconize it at all I was wondering if there was a code or what else can i do to get a code have already tried to search 4 a code too
  • 319 Answers
What is the make/model of your remote?
Posted on Jan 02, 2008
SOURCE: one for all remote 4 urc 7544 old model need code for samsung 5 series tv
lost the code book /i have a sanyo tv cannot remember the codes for it
Posted on Sep 17, 2008
SOURCE: Innovage Jumbo Remote Control codes for Viewsat Satellite Receiver
buy a harmony 550 remote
Posted on Sep 30, 2008
SOURCE: Need universal remote control codes
Well I have a nexx tech universal remote control model 1519001B but I lost the code list and I nedd the code for a JVC tv.
Posted on Nov 11, 2008
SOURCE: What is the remote control code?
I finally got mine fixed yesterday. The room code has to be set to 1. The VIP 612 has to be on. A phone call to Bose provided me with about 4 more codes that were not included in the setup manual, and one of them worked. Good luck with the set up, hope this helped.
Posted on Apr 28, 2009
SOURCE: Broksonic TV code for RcA RCU704 remote control
I had a similar problem with a 1994 vintage Broksonic TV. I called the company (Hatzlachh Supply Inc. @ 800-333-9099). Broksonic TVs are not compatable with any universal remotes! You need an original factory remote. Remote for my set cost $20.00 plus shipping for a total of $24.95.
James Benson
Posted on May 27, 2009
0 characters
1 Points
I have 4 TVs using 2 receivers. TV 1 and 2 use receiver VIP722K. TV 3 and 4 used receiver 322G. I bought a new Vizio tv to replace TV 4. (Note: TV 2 is also a Vizio) I tried to set up the new Vizio...
Hi, Cheri Torres with DISH Network Customer Service here. Icame across your question and wanted to see if I could help. It sounds like youmay need to either readdress your TV4 remote to your 322 DISH receiver or youcould possibly have receivers for TV2 and TV4 mixed up. Since your TV4 has "Pressselect to watch TV" on the screen you can check both of your receivers andwhich ever receiver has the TV2 blue light off is the receiver this TV runs offof. If this is not the case and you are positive that the TV4 does run off the322 you will want to take the remote to the receiver box location in order toreaddress it. I will list here for you the instructions for readdressing theremote to the receiver box. I hope you find all this information useful and ifyou have any other questions or this does not fix the issue you are experiencingfeel free to email me at Thanks and have a greatday!
Instructions for readdressing your remote to your DISH receiver
  1. Go to System Info screen. You can do this by pressing the power button once then the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see primary remote address and secondary remote address.
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the little white square for secondary remote address.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Feb 16, 2011 | DISH Network IR Remote Control
Remote codes
the 4220 does have SAT code 1377 on board, and will work with the following Directv sat receiver models: D10, D11, R15, H10, H20, and HR20.
Try code: SAT1377
What address is the D10 set to, DTV (00001) or AV1/AV2 (00002)? SAT code 1377 is for receivers set to white remote native code 00001.
to blink back the code on the white remote:
1. dtv
2. press and hold MUTE & SELECT for two blinks
3. enter 9-9-0
4. press #1 key, it won't blink because the numeral is zero
5. press #2 key, same as a above, zero blinks
6. press #3 key, zero blinks
7, press #4 key, zero blinks
8. press #5 key, this should be 1 or 2 or 3 blinks
Mar 31, 2010 | One For All URC4220 Remote Control
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
Eaglestar pro 53-0305 / nFusion HD codes
i have eaglestar receiver. i watch hindi programs. since jan/09 its not working. people tell me to buy new receiver and new dish. what should i do?
Sep 12, 2009 | Universal Remote Control Remote Control
My dish network dvr625 tv2 remote will not work with receiver. I just bought it used to operate a third tv. Does it need to be programmed?
Bring up the System Info screen (Menu 6-1-3, or System info button on front panel). On the lower right hand side you will see the address of the UHF (TV2) remote. On the new remote press and hold the SAT key 'till all the top buttons light once you release the button it should it flash. Then press the number on the key pad the receiver is set to, then the # key. The Sat key should flash three times locking the new code into the remote.
Jul 10, 2009 | Remote Controls
Jan 07, 2009 | Bose RC-18S Remote Control
Nexxtech 4-In-1 Unvirsal Remote Control
1800 , 1014 , 1032 , 1034, 1049 , 1050
Mar 16, 2008 | Remote Controls
How do I program the JENSEN RC-S11-0C
How do I program my jensen SC-570 Universal remote to a emerson tv dvd player.
Jan 13, 2008 | Jensen SC-570 Remote Control
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Oct 28, 2007 | Remote Controls
Remote Controls Logo
47 people viewed this question
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
