AEG Lavamat 6250 - opening door?
I received a used AEG Lavamat 6250 washing machine. The door closed tight with no handle, how do i open it? :(
  • dudicon Nov 12, 2009
    actually just found out how to open it. I pressed a button labeled "TUR AUS" for several seconds.
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Try spoon handle gently prise open
Posted on Nov 12, 2009
  • Gerry Harvey
    Gerry Harvey Nov 13, 2009
    Sorry thought that you were meaning Handle was broken....Glad alls well
  • 22 Answers
Press door button until door opens. It may take a while if there is water inside. Water will be pumped out first.
Posted on Aug 21, 2010
Can't open door
the two possibles are faulty door lock or water still in the machine. the error code should tell you which. go to AEG and their troubleshooting page will give you the codes.
Jan 30, 2013 | AEG Lavamat 72640 Front Load Washer
My 72640 AEG washing machine continually leaks even though the filter cap is tightly in place. What could be the problem please? Kate Comins
you have a hole in the rubber boot seal and need to change it,also i've seen a buildup of detergent and hair stuck on the bottom side of the front door,when the door is closed the water was traveling down the pieces of hair and leaking through the bottom of the door,but if it's leaking under where the pump is and it's not the pump or hoses it's the boot seal.open the door and pull open the boot seal and run your fingers all around until you find the hole
Jan 23, 2011 | AEG Lavamat 72640 Front Load Washer
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 74800: Door doesn't open, i.e. opens with long delay
Following next link:
How washing machine door lock works how to test interlocks
Replace door lock.
untitled2-rq2y3fnvghvfrpvxa33jafnd-1-0.jpg When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5) is powered by the triac on the PCB (J6-2 connector): after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed).
The door interlock prevents aperture of the door while the appliance is in operation.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
Certain models feature a pilot lamp which lights to indicate that the door is locked. This pilot lamp switches off when the door can be opened.
Dado
Mar 17, 2017 | AEG Lavamat 72640 Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG Washing Machine: Door won't close
Hi again,
Any updates/development with your project?
Jun 21, 2008 | AEG Lavamat 74640 Front Load Washer
AEG lavamat
For user's manual: Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, & your manual is on line. Wait for at least 3 minutes after the wash is complete, to open the door; do not force the door. The door will not open immediately on the wash being completed.
Dec 25, 2007 | AEG Lavamat W1050 Front Load Washer
AEG Lavamat 72620 door does not open
It seems that your problem is with the lid switch and it should be replaced. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Good luck!
Sep 05, 2007 | AEG Lavamat 72640 Front Load Washer
Door not unlocking
open the filter door at bottom turn screw with coin , door should open ,
Oct 02, 2006 | AEG Lavamat Lavalogic 1600 Front Load...
Washing Machines Logo
596 people viewed this question
Top Washing Machines Experts
