I have a simpson front load washing machine and it is not draining?
  • 155 Answers
Apart from having a faulty water pump check to see if you have a blockage maybe filter is blocked or something caught in drain hose alternatively you might have a control or wiring problem let me know how you went
Posted on Nov 12, 2009
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
I have a simpson washing machine that doesnt drain after wash what could be wrong
water pump or water pump solenoid
if they check out ..faulty timer
to drain water out
have to put the drain hose on the ground out the door
or towels and buckets
Sep 17, 2016 | Simpson Esprit 750 Top Load 7.5kg
Simpson front load washing Machine ..Coming up with error code "E10"
E10 relates to inlet water supply not being adequate. Please check kinked inlet hoses, inlet water filter blocked, insufficient or no water is getting is getting to the machine.
Jul 22, 2016 | Simpson Washing Machines
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
How do I get my washing machine to spin
Check the interlock tab (upright models) or the hinge or latch switch (front-load.) Sometimes these switches break or simply come loose.
Aug 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
GE WWSE5200B Top Load Washer does not drain or spin
Jim, we have same problem with Simpson top loader washing machine.
Our repairer eventually diagnosed it as a problem with the electronics but it can't be fixed. So we have a 3 year old machine with good pump , motor, gearbox etc but need to buy new machine now. Yours might be similar problem. Don't buy a simpson. Sorry, this is just what we've been told.
Jenny
Dec 03, 2011 | GE WWSE5200B Top Load Washer
My Simpson Esprit 655 washing machine is not the spinning the clothes dry. Everything seems to be ok.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | Washing Machines
Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
