Question about HP DeskJet F4280 All In One Printer InkJet
My HP F4280 all in one printer cannot print. the three lights keep blinking. I have paper in the feed tray, and ink that came with the printer correctly installed.
  • 855 Answers
Have you used the disc and installed it on your computer as per instructions? If not or if you used a usb cable and plugged it in too soon, or the installation failed to install all programs for the printer and needs to be reinstalled amd set up again properly.
Posted on Nov 12, 2009
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
I bought my hp deskjet f4280 over 2years ago and i kept it without using it. It was brought today and i discovered that is not printing. The resume red button is blinking. Several test pages were sent to...
well, i would guess that you are using the ink cartridges that came with it.
The ink actually has an expiration date like food, and more thab likely the ink has dried up. If the printer is reading the ink levels, is may count them as being empty.
Try getting new ink and see if that works, as that is most likely the cause of the fault.
Dec 16, 2010 | HP DeskJet F4280 All In One Printer InkJet
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
HP F4280
Once you open the front panel with the printer on, you should have the ink brought to you. Both should all come to the front from the side of the printer so you can replace it.
Aug 18, 2009 | HP DeskJet F4280 All In One Printer InkJet
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
My Hp printer keeps saying "resume".
Do a complete reset.
1- Clear the printer queue.
2- Turn off the device.
3- Remove paper in the tray and possible paper jammed.
4- Remove ink toner.
5- Turn on the device briefly and turn it off.
6- Replace paper and toner.
7- Turn on!
Mar 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
Light blinking
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Jun 02, 2008 | Epson FX 1170 Matrix Printer
HP DeskJet F4280 All In One Printer InkJet Logo
251 people viewed this question
Seeker5211
Seeker5211
