Question about Vtech Kidizoom Digital Camera
What size sd memory card do i need as the sd card i have at the moment is too big
Trying to set up a VIA1535TM. Looks like I need to add a SD card to download maps update. What size and type doI need to use?
I just checked in my old GPS and it had an 8Gb class 6 and I never had issues. Those you should be aware a lot of those devices won't work with SD cards larger than 32GB,. It's an operating system limitation.
Dec 31, 2017 | GPS
Memory card full
If you already used the card in the same camera, the only thing I can think of is you did switch the lock switch on the SD memory card. Or there must be one or more protected images on your card. If the card comes out of another camera be sure it is a SD or a SDHC card, not bigger than 16 Gbyte because a SDXC card would be one size to big. The manual says max card size 16 GB
If you accedentely formatted the card in the PC (or MAC) it could be you did put a format on the card the camera does not understand. Most camera's use FAT (max 32) and never NTFS.
Try to format the SD card in your PC.
Nov 04, 2013 | GE X500 Digital Camera
Is 16gb sd card too big for samsung a503
It's not the size of the camera so much as the age. The A503 was designed to work with SD cards, which max out at 2GB. It will not work with newer, larger SDHC cards. You need to use SD cards, 2GB and smaller.
Jul 19, 2012 | Canon PowerShot A530 Digital Camera
Samsung L700 memory card not working prints r not avialable 1 2 5 i wanna jumpers of samsung l 700 memory card
Although no memory card specifications (except that it should be SD or SDHC or MMC card) is listed in the PDF manual, the problem most probably is that your card might be incompatible (I've personally experienced card's incompatibility with other digital cameras):
1) Borrow different SD or SDHC cards from your friends and try on your camera.
1) Check cards of different speed classes (number 2, 4, 8 or 10 inside a circle on the card): Normally if you have smaller SD cards (up to 2GB), it might suffice that card's speed class is 2. If you have larger SDHC cards (4GB and more), your camera might require a speed class of 4 or more. Or it may also happen that your card is too fast/big - some older devices don't work with too modern SD/SDHC cards. Read more about SD card speed classes>>
2) Check cards of different sizes. Some cameras my not work with too small or too large size cards.
3) There are plenty of fake SD/SDHC cards on ebay (mostly from China, with unidentified manufacturers/brands) which don't work with many devices and cause many errors. If there's a size and speed class written on such fake card - don't trust these numbers, they are probably fake.
3) If none of the different memory cards work - bring your camera to the mechanic
However, these requirements may vary from camera to camera. So ask about your Samsung L700 camera directly at Samsung customer support form>>
There are several websites where you can match your camera with compatible SD/SDHC cards:
Mar 05, 2011 | Cameras
Is there a maximum SD memory card that I can use on my Panasonic Lumix DMCZ7. I have tried to use a 16 & 24Mb SD card but the camera will not read it and displays a ' card error reading message'
I think you mean 16 and 24 GB (Gigabyte), not MB, but those would not be SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If you really mean 16MB, then that would be rather small, not too big. 16MB is definitely compatible with the camera and is mentioned in the manual.
The maximum memory card size mentioned in the manual is 1GB, and that is quite big enough. If you really need more space, then just carry a spare, like people used to take extra film with them on holiday.
Dec 09, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
What ext. max size of memory for cd14
According to Kodak, your camera will support the use of SDHC cards up to a maximum capacity of 32GB. It will also accept any capacity of SD card up to the maximum SD format size of 4GB.
Please take a moment to rate my answer.
Sep 16, 2010 | Kodak Cameras
What else is necessary besides the micro sd card to download pics from cell phone to computer? why big card and little card?
why big card and little card? well on cell phones they have gone smaller than 10 years ago, so the memory chips fro them has gone small to, if you have a memory card reader usually you will need to use a micro sd adapter so it will make the little one into standar SD size, and it will fit in any card reader machine even at walgreens, target, walmart etc.
in this case you don't need any special software.
if you try to connect the phone directly to the pc in most of the cases a DRIVER is needed for you phone work as a external mini harddrive !.
hope it isthe answer you are looking for.
Oct 07, 2009 | Computers & Internet
How big memory card can be used
The specs say any size sd card, but it does not say sdhc card, so
I would think that it can only see a 2g max card. Sdhc cards are over 2g.
Apr 06, 2009 | SanDisk 2GB microSD Memory Card
Optio 30 SD Card Max Size
You can now get up to 2.0 Gigs (that's 2048MB) of storage on a MiniSD card and all you would need is a SD Adaptor. The following site has MiniSD cards that are 1.0Gig (1024MB) or 2.0Gig (2048MB) and they come with FREE adaptors! http://www.flash-memory-store.com/mini-secure-digital.html As technology increases so will the story size. They are talking about making MiniSD cards that are up in the 5.0gig (5120MB) area. Enjoy!
Aug 30, 2005 | Pentax Optio 30 Digital Camera
Vtech Kidizoom Digital Camera Logo
108 people viewed this question
Top Vtech Cameras Experts
Tony
ray gallant
Are you a Vtech Camera Expert? Answer questions, earn points and help others
