Question about Brother MFC 7420 All-In-One Laser Printer
Printer will not print with screen saying back cover open. Back cover is closed.What else can be open? Regards Nigel
  • 2 more comments
  • ntitchmarsh Nov 15, 2009
    Taran 2005 my back cover is just one piece of plastic. Where is the rod found you are refering to? Nigel
    Taran 2005 where is the rod you are refering to because the back cover I have removed is a one piece of plastic. Nigel
  • ntitchmarsh Nov 17, 2009
    Followed your instructions and have removed spring but now do not know how to put it back together. How is this done? ntitchmarsh
  • ntitchmarsh Nov 18, 2009
    Problem solved. Thankyou for your help
    President:
  • 1,566 Answers
Hi Nigel,
The error could be related to a jammed paper at the back. Have you tried this troubleshooter from Brother's website:
  • This is usually down to paper being jammed in the back of the machine holding the inner cover open.
  1. Open the Back Cover
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the blue tab with one hand as you gently pull the paper out with the other hand.
  1. Printer will not print with screen saying back - backcover3.bmp Cover.
Posted on Nov 17, 2009
  • 10,515 Answers
There are a couple possibilities here that cause this error:
(1) You have a paper jam somewhere in the printer. Check it throughly and make sure nothing is jammed anywhere.
(2) A possibility from another user:
"Ok I fixed this problem. It has to do with Tension on the rod inside the back cover. Open the back cover and remove it. Then emove the black plastic piece by un hooking it on the left side and pull it down then toward you. You will see a rod attached to it that runs to the right. The right end of the rod has a lever that travels in a slot on the right side of the printer. There is a small spring on the rod. Here lies your problem. There has to be enough tension on this spring to activate a switch in the slot on the right side of the printer. Make sure the spring is installed properly. This is a low tension spring so nothing will come flying out when you remove it and re install it properly. A piece of paper can dislodge this spring. When you get it apart you can quickly see how it should be put back in."
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 15, 2009
  • taran_2005
    taran_2005 Nov 15, 2009
    Thanks for your response!!
    Open the back cover and pull it out of printer .Inside you will find a
    black carrier for the paper to deliver it to the top part of the
    printer . Pull it down and dislodge the left side then pull off the
    right . On this black carrier is a plastic rod which has a lever to the
    right . This activates the sensor on the right side of the printer .
    There is a small spring located on the plastic rod which needs to be
    re-tensioned as much as you can then put it back in . Replace the black
    carrier and finally the back door . If your still having problems you
    may need to find a stronger spring and replace .
    Hope i helped you.
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
How do I fix Error code Oxc18a0206?
Hello, U may try these steps FIRST -
1 Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB cable, and try to print a print job from the computer.
In case the above steps does not help , You may try the following steps SECOND -
Get the unit into the "Support Menu" by following the steps below according with the product, see the steps below:
    A.- Press and hold the "*" key. B. - Press the "#" key and release both keys. Display should say "Enter Special Key Combo" C. - Press and release in sequence the "1", "2" and "3" buttons.
    2. Press and release the right arrow button until the display says "System Configuration Menu".
    3. Press and release the "OK" button.
    4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    5. Press and release the "OK" button.
    6. Display should say "Hardware failure status: Clear. Press OK to clear".
    7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
    I hope this helps !!!!
    If the error is still there, sorry U are out of luck - might need to change the printer as per me.
    Regards
    PS
Jul 13, 2014 | HP Photosmart C6180 All-In-One InkJet...
Screen displays message saying "cover
It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. Reinsert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
Ink system faillur hp offiejet 6500
Try these steps submitted by another user on FixYa:
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
10. If the error is still there Try below:
1. Get the unit into the "Support Menu" by following the steps below
A. - Press and hold the "*" key.
Display should say "Support" and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
14. If the error is still there, or reoccurs replace the unit.
Regards GM
Apr 22, 2011 | HP Officejet 6500 Wireless All-in-One...
The screen says the "back cover is open" and
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 24, 2011 | Brother DCP-7020 Black and White Copier
Printer quit printing. Screen says fuser cover is open. Where is it located so I can close it?
Your problem: paper is jammed in the back of the printer around/in the fuser.
The Users Manual for your printer is located at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users Manual/UM_DCP_7030_7040_EN_1510.PDF
You'll need Adobe Acrobat Reader (free from www.adobe.com) to view it.
LOCATION:The fuser cover is located in the back - its covered by the panel in the back called
the "back cover" aka "back output tray cover".
2-step fix:
(A) open the back cover - on the back of the printer.
HOW: it flips down
(B) open the fuser cover and remove paper jam
How: Pull the 2 tabs (one left and one right) toward you to open the fuser cover.
(it also flips down to open).
Most of this fix comes from downloading the Users Manual and blowing up page 60 (of 108 pages).
Jan 01, 2011 | Brother DCP-7040 Laser Printer
Says can't print because top cover open when it's not. Tried resetting by pulling plug, re-opening and closing top cover.
this is the common problem of 5150 printer .you just open the top cover ,in your right hand you can see a black moving part it may not working properly. try to move back and forth many time ,then close and check your printer.
Feb 12, 2010 | HP DeskJet 5150 InkJet Printer
HP Photosmart D7260 Ink System Failure Error 0xc18a0206
1. Disconnect the Universal Serial Bus2.gif (USB) cable from the back of the product, but leave the product turned on.
10. If the error is still there replace the unit
1. Get the unit into the “Support Menu” by following the steps below
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen2.gif)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure2.gif” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Good Luck
Oct 20, 2009 | Office Equipment & Supplies
Printer stops printing half way down page
Solution Use the instructions below to resolve the issue by restarting the product.
  4. Disconnect the power cord from the back of the product and wait for one minute.
If these steps did not resolve the issue, contact HP technical support for assistance.
Apr 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Error with printer
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
If this does not work, contact HP technical support for assistance.
Jan 13, 2008 | HP PSC 2355 All-In-One InkJet Printer
Brother MFC 7420 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
