Question about ASUS NCLV-D Motherboard
2 SHORT BEEP AND 6 BEEPS ON BOOT Asus NCLV-D motherboard
    Sergeant:
  • 267 Answers
2 short = Parity circuit failure 6 beeps = Keyboard controller Gate A20 error
make sure all hardware is installed properly
retrace your connections to insure all parts
were installed correctly. you may have to disconnect and start from the
beginnig to correct this problem. disconnect all unneccesary prephrial
leave only the mouse /keyboard and monitor hooked up and try booting again . eliminate as you go to narrow down to the problem.
Posted on Nov 12, 2009
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
1 long beep and then 3 short beeps
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
It seems to be a graphic card problem, or the power supply not giveing enoug power.
Try to change the graphic card.
If you are useing the onboard graphic, look for bad caps on the mainboard:
If they look like this, the mainboard is dead.
Good luck
Feb 16, 2013 | ASUS P5KPL-AM SE Motherboard
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
Asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Sep 05, 2009 | ASUS P4P800-VM Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
My computer does'nt boot
Check your Cooling Fan. Sounds a LOT like the fan is getting Sluggish and not cooling the Board Properly.
Jan 20, 2009 | ASUS P5LD2 Motherboard
Asus Mother Boards - Beeps, Boots, Windows Login Sound, No Image
Yaa you are right. try to boot in Safe Mode and check out driver for display, otherwise you have to change your display card.......
thanks
iqbal
Apr 02, 2008 | ASUS A8N-SLI Deluxe Motherboard
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
ASUS NCLV-D Motherboard Logo
166 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
