Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Stopping people from outside my house connecting through my wi fi to my internet
  • 2,263 Answers
You have a wireless network and you want to stop people from accessing your wireless network. For this you will need to secure your wireless network. You will need to enable the security on the wireless network.
You can do it by accessing the router set up interface.
Make sure that when you will change the wireless settings on the router, your computer will be connected to the router with the cable.
Click Here for step by step solution
Posted on Nov 12, 2009
  • Gateway Master
  • 32,281 Answers
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Not connecting to google server. Even there is wifi connection.
There is a difference between establishing a Wi-Fi connection, than the connection to your internet. Although you see a connection with your Wi-Fi, your Wi-Fi is just like a cordless phone connection. You remember those old rotary phones you would have to charge on the charger/ receiver (Which is connected to the phone cord outlet on located in the wall). Just as how WiFi works, The range is limited. Just because you have no problems with your WI-Fi connection, you may not have an internet connection on which it may have something to do with your ISP (Internet Service Provider). The best way to find if you are communicating out side your home network, Open the "COMMAND PROMPT" Type ; ping google.com (press Enter)
If you are communicating out side your home network you should get results like this displayed below;
Pinging google.com [216.58.216.46] with 32 bytes of data:
Reply from 216.58.216.46: bytes=32 time=39ms TTL=52
Reply from 216.58.216.46: bytes=32 time=40ms TTL=52
Ping statistics for 216.58.216.46:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 39ms, Maximum = 40ms, Average = 39ms
If you're not communicating out side your home network; it will display.
Ping request could not find host google.com. Please check the name and try again.
Wi-Fi is to connect your devices to the Gateway (Wi-Fi Router/Modem) which your gateway provides the connection to your internet. You are not having problems with your Wi-Fi, you're having problems communicating outside your home network. When this occurs, unplug your Gateway (Modem/Router) and check to see if it restores your connection. If this does not work, call your ISP to check for outages. Other situations is not paying your internet bill which may have caused your ISP to disconnect your service.
Oct 24, 2017 | Google Computers & Internet
My ipod says no internet connection but my coputer is on line
Hi Kate, try turning your cell phone off then on.... If still no Wi-Fi Hi, and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
Apr 04, 2016 | Apple iPod touch
I CAN CONNECT TO WIFI FROM MY HOUSE BUT CAN NOT OUTSIDE.. HOW CAN I CONNECT OUTSIDE MY HOUSE? CAN I PURCHASE SOMETHING?
Perhaps the WI-FI signal outside your house is very low maybe try to place your router in a much higher place in your home so that it can strengthen the WI-FI signal..Hope it will help you
Jul 02, 2011 | PANDIGITAL Novel 7
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
How do you get the psp conected to the network
you have to be in a wi-fi area if you have high speed internet at your house you need a network router this will set up wi fi at your house so you can connect internet from your house if not go to a wi-fi hotspot then make yourself a playstation network account. I hope this helps you.
Dec 24, 2009 | Sony PlayStation Portable (PSP) Console
My new 8G touch IPOd won't connect to a wi fi
try hooking it up on itunes and updating the software ive heard of people having some issues with the internet untill they updated the software on it
Sep 29, 2009 | Apple iPod touch
I can not connect to the internet on my psp
There are different ways to connect to the internet. First of all, you need a Wi-fi Network. This can be done by purchasing a Router. This allows internet signals to "circulate your house". If you want to be cheap, you can go to Starbucks or McDonald's and Wi-Fi should be free there.
Sep 15, 2009 | Sony PlayStation Portable (PSP) Console
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Permenantly connected to the internet
Go to the following options
Settings > Wireless Controls > Wi-Fi Settings > Menu > Advanced > Wi-Fi Sleep Policy
This would stop the interent connection.
Thanks
Proton
May 21, 2009 | HTC G1
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
119 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
