I require a replacement drive gear (the one that connects to the motors worm drive)for Fellows shredder model P50cm. I reside in Wangaratta, Victoria, Australia. Are you able to provide me with an Australian spare parts agent.
  • 610 Answers
Only Phone # I have is for Fellows-USA 1-800-955-0959. they may be able to direct you to local service center.
Posted on Nov 18, 2009
I need nylon gears for a p50cm fellows shredder
you can try the manufacturers web page for spares but generally if it need parts , it will be too costly to repair so consider junking it and getting a new one
Feb 15, 2017 | Shredder Office Equipment & Supplies
Replacement gear required
There is a YouTube video on this.
Dis assembly and Repair of a Fellowes paper shredder - YouTube
www.youtube.com/
My fellowes paper shredder stripped a gear. Here I open it up and fix it with out needing to buy replacement parts.
Jan 29, 2014 | Fellowes P50CM Shredder
Repair
There are no adjustments for this machine. Chances are that the plastic gear that is driven by the worm gear has a spot that is worn down and when worm gear hits this spot, it does not drive . Replacing gear is the only remedy. Good luck.
Jul 13, 2013 | Fellowes MS-460Ci Shredder
PS60C-2 Shredder: Fellowes P50CM paper shreader motor runs but cutte...
One of the drive gears has stripped its teeth, usually caused by overloading the machine. These are personal shredders and parts are not available in my experience.Sorry.
May 03, 2010 | Fellowes Office Equipment & Supplies
Only one Shredder roller turns
you have a broken gear.try calling 1-800-955-0959 to see if Fellows makes replacement parts for that model.
Nov 24, 2009 | Fellowes OD1200 Shredder
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
The gear opposit the drive motor broke (driven worm gear)
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Dec 19, 2008 | Fellowes P70CM Shredder
245 people viewed this question
jasbo
jasbo
