Question about Apple iPod nano
Washed ipod in washing machine can anything be done?
  • 105 Answers
Try to dry it with heater you may be on the luck side, if not that means you get another one
Posted on Nov 12, 2009
Why does the masjiene not wash clean brown spots on dishes and glases
It sounds as though your machine needs a maintenance wash. Remove the filter and clean thoroughly, replace. Purchase a dishwasher cleaner, follow the directions on the cleaner. Do not put anything in the machine (dishes, cutlery etc) when doing the maintenance wash. Make sure when using the machine that you use a good quality tab or powder in the future. A maintenance wash should be done every six months.
Jan 03, 2018 | Dishwashers
Washing machine drum is not rotating
There may be a blockage. My washing machine had done this before. If your washing machine has the rubber outline around the drum I suggest running a finger around to make sure there isn't anything preventing it. Otherwise I would suggest phoning the store you purchased it from and asking if it is still warranted
Jun 01, 2013 | Washing Machines
Kenmore 80 Series Washer is not draining. Worked fine for first wash last night, but did not drain on the second. Anything that can be done by us to check this problem?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 25, 2011 | Kenmore Washing Machines
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | LG WM-2277HW Front Load Washer
Kenmore washing machine mod 110.20982991 that does not drain
Not too familiar with this. You could locate where your pump is to see if anything is clogging the impeller. Usually this is it. You only have to remove the clog.
Mar 19, 2009 | Kenmore Washing Machines
IPod shuffle got wet in the washing machine
If you've been trying to turn it on, then it's unlikely to work again. If anything like that happens again, "DON'T TURN IT ON". Take the item apart carefully keeping the screws together and leave the parts spread out in a warm dry place like an airing cupboard for about a week. Then put it back together and cross your fingers.
Nov 11, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Washed Ipod
yes becaus the water soak in to the base bard of operations and probaly made the batteries dye
Sep 21, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod washed
i dought it! take it apart and let it dry out
Crack open Ipod
http://www.markovic.com/blog/2006/02/28/how-to-open-a-ipod-g4-without-real-tools/
Jan 28, 2008 | Apple iPod nano
Washer
Probably your inlet pipe is clogged, or not open sufficiently. Plug off the wall, turn off the inlet pipe, disconnect tube to check carefully if anything is blocking the fine screen on both sides of the pipe. Also check the machine screen where water comes to the machine. It is good to close the inlet valve after your washing is done.
Rate me pl.
Nov 29, 2007 | Fisher Paykel EcoSmart GWL15
Washing machine
Check the brushes in the motor. They've probably worn down and need replacing.
Oct 06, 2007 | Washing Machines
Apple iPod nano Logo
95 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
