Question about Tascam DP01 All-In-One Recording Package Microphone
Can't erase song - error messege appears
I tried to copy a song from partion 1 and move it to partion 2. Partion 1 was full and when I did this it copied over top of the last song on partion 1 twice. Now I cant remove the copied song. If I try to erase or load the song a messege appears that says "Error 51 please switch off.
    Sergeant:
  • 243 Answers
You may have corrupted the memory format it.
Posted on Aug 22, 2008
  • Nathan Ayers
    Nathan Ayers Aug 23, 2008
    lemme know what works.
Fujitsu lifebook will not bootup. Message says "operating system not found."
Couple of things here, 1. Your os/nos is missing or 2. your boot files have been moved to another partion and the server has not been directed where to look.
Solutions: reinstall the os/nos or find the correct partition which has the boot sector and direct the server to boot from that partion. (This partition should be partition 0.
Good Luck
C2Solutions
Jan 23, 2010 | Fujitsu Siemens Siemens PRIMERGY B210...
I cannot install vista or win7 , after installing the fast stapes wen the computer restart the err will appear a drive err
pls explain you actual fault in detail, without full error no solution can be suggested.
to install vista / win7 you need to two partion of the
primary HD, in the first partition(c:) install WinXP and then install Vista in the other partion (D:/E:/F:/G:) etc, when the pc boots you need to chose(down arow/up arrow keys) the OS that you need the PC to load.
Dec 07, 2009 | Foxconn G31MX-K socket LGA775 motherboard
How do i get rid of the eisa partion on my hard drive, i have an acer T180 with a 160GB HD
Not quite sure if the partion is the primary or secondary. If it is secondary and you are running Vista, go into the Admin Tool in the Control Panel, select Computer Management, select Disk Management under the Storage tab. Select the partion you want to erase from the bottem partion of the screen, right click on the partion, and choose Delete Volume.
If you are deleting the primary, you will need to use the upgrade function to get a clean deletion of the old info.
Good Luck
C2Solutions
Jul 29, 2009 | Acer Aspire™ T180 PC Desktop
SanDisk Sansa e250 MP3 Player wont work
find a way to format it.youll lose all of the songs but it will work again.best bet would be is to use a xp installation disk.boot off of it and go to the partion of the mp3 and delete it and create a new one.you might want to format or you might not have to.if you format it stop it before xp starts to copy files to for the os.make sure you get the right partion.if you got any more questions please email me at gamecrazy944@yahoo.com
Jun 21, 2009 | Microsoft Xbox 360 Arcade
I am having 8 gb transcend flash my flash was plugedin the usb of my computer. i was trying to use norton ghost for one hard disk.it was asking me for some option i dint see and started preesing ok ok .....
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Unable to make partion
Domez,
Try Testdisk to see if it can restore the boot sector.
Chappo07
Sep 02, 2017 | Seagate (ST3160827AS) 160 GB Hard Drive
I can't make format, partions or install windows.
Hi shlmughni,
If you're trying to format this drive, and you have nothing on it you want, then I would suggest that you use a windows 98 boot disk HERE. And first thing you need to do is load dos by putting the floppy disk in your drive A: after you create it from that site of course. Then allow dos to boot up. I'd opt for the allow cd rom option when it asks. After you get a dos prompt A: type in fdisk. Go to the display partions section and see what your drive is partioned as? Once you find that out, I'd delete the partion from the main menu choice delete partion. After that create a new partion from the main menu. Creating a new Dos partion will allow you to choose the size of the partion you want, then after that it will create your new Dos partion. When that's done, exit fdisk, and go to the A: prompt and type in format c: This will format the drive all over again, and give you a clean fresh starting point in which you install your OS.
Good Luck
Mark
Jan 03, 2009 | Maxtor Hard Drive
Hard drive
http://support.microsoft.com/kb/313348
Apr 08, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
U3 launch pad error
Download Gparted disk partion tool, use the bootable ISO burn disk. Now boot PC with gparted and on the desktop is a icon for mounting usb drives, use this to mount the usb stick.Follow the instructions, when asked to install gparted on disk exit window by using "q+enter" key.
Now start the partion tool and mount usb drive and partion and format.
An alternative method is to use the partion tool found in most linux distributions such as in puppy or mepis.
Mar 19, 2008 | Electronics - Others
Missing
well check ur hardrive in slave to an other system and then see if it show the missing partion then copy the data and format it.
if it wont then use partion software to check it like partion magic.
may be your system changed the partion to RAW format i mean UNPARTITIONED space due to improper shutdown.
Jan 06, 2008 | Computers & Internet
Tascam DP01 All-In-One Recording Package Microphone Logo
50 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
