Question about Nokia N73 Cellular Phone
I have chinese copy of N73. when i try to charge it through charger after some passage of time it shows BAD CONTACT ERROR and stops charging. moreover, if i charge the battery through universal charger and insert the battery in mobile and switch on it then it shuts off immidately or after some seconds
2 Suggested Answers
erone47
  • 458 Answers
SOURCE: N73 shutdown
chinese versions of nokia phones are duplicates and fakes, they are pirated. there is not much you can do with them and it is a big risk to buy one. i wouldnt advise you to get any chinese version of any nokia phone.
the only way you might charge it is through a universal charger. make sure you have connected the betery corectly and then charge it till its fully charged. if that does not work, try getin a new batery
Posted on Jul 13, 2008
Hi, I am from Pakistan, i bought a k770i Sony Ericsson set the set is showing me the that erorr "k770i stop charging.stop using your phone and contact a sony Ericsson call centre" whats...
Try with another charger. If it still shows the error, try cleaning the gold contacts where the charger connects to the phone and connect the charger again.
If the error still shows, try replacing the battery.
Finally, if none of the above work, you'll have to contact Sony Ericsson to fix your phone.
Mar 05, 2011 | Sony Ericsson W380i Cellular Phone
Whenever I charge the battery, the orange light on the charger won't light up/show. Then, when I put the battery in the camera, it will not turn on.
Rechargeable batteries don't last forever. This one may have simply stopped working.
However, it is worthwhile checking that the contacts on both battery and charger are clean. Dirt or corrosion can prevent the battery from charging.
There is also the possibility that the charger has failed. You can buy a new battery and try charging it. If it charges, then the charger is good and the old battery was the problem. If it doesn't, then you must get a replacement charger, and you will have a spare battery, which is no bad thing.
Oct 27, 2010 | Cameras
We ran our Platinum Series 18 volt hand vac until it stopped -- charged the battery overnight but it did not charge. is there a problem with the battery charger or what could cause this?
Most problems with what you have stated have to do with bad contacts between the hand held unit and the battery charger. With the charger unplugged, make sure the contacts on both the charger and hand held unit are clean and not bent. Check to see what the "Light Indicator" should be when charging and reinsert the unit into the charger. If the light does not show what it is supposed to show, move the hand held unit around a bit to see if you can make the connection better.
If this does not do the job, depending on the age of the unit, might be time to replace the battery.
Oct 06, 2010 | Black & Decker CHV1500 Bagless Handheld...
Hi have mini iphone (ka08). Was working fine but battery ran out and will not charge switch on etc! Have replaced battery and charger..still no life!any ideas??
Mine does the same thing, but i play with the female part of the charger ( the slot inside the phone ) BAM it starts working again. Its just a really poor job on the charger part its really cheap.
Nov 24, 2009 | Cell Phones
Bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
Nov 03, 2009 | Cell Phones
Charger Error Pop Ups
dear,
this issue directly related with the charging circuitry... the issue can either be with the charger itself or majorly with the charging ic ...
i had faced this problem with the chinese mobile phone but this can be either with the chinese model or can be with the other...so check the both things one by one...hopefully the issue will be resolved..
regards,
dont forget to rate this if issue resolves.....
Jul 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
Mar 07, 2009 | Nokia N73 Music Edition Smartphone
NOKIA N73 PROBLEMS
my n73 hand set problem is if i connect the charger on the screen displayed not charging, and i use to charge the battery charger to store power in battery. charger is working fine but hand set troubled me and the other problem is if i listen the music files after 2 minutes phone is off, in a day its happening lot of times give a complete repairing solutions.
Jul 16, 2008 | Nokia N73 Cellular Phone
N73 shutdown
Jul 12, 2008 | Nokia N73 Cellular Phone
My N73 is not charging
try to replace ur charger, coz charger not compatible to your phone.
Feb 07, 2008 | Nokia N70 Cellular Phone
Nokia N73 Cellular Phone Logo
117 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
