Question about IBM Lenovo ThinkPad R60 Notebook
My IBM Lenovo R60 laptop is unable to detect my wireless router but I am able to connect to the wireless router using my other laptop and I am also able to connect to other wireless connection in the area but just not my own? I have checked that wireless is enabled on the laptop and that i have entered all the wireless details correctly ie the network codes match name of wireless is correct. I recently had to carry out a system restore using my xp disc so im not sure if that would have affected it.
  • dalbs1 Nov 12, 2009
    Thanks for the reply.
    I will take your advice on however, im not sure if the problem is with the laptops driver as i can connect to other wireless connect in my area just not my home wireless network.
    When trying to connect i seem to connect but i get a looping Aquiring network address
  • 98 Answers
SOURCE: IBM R60 thinkpad Audio prob
Try to install all the new drivers from this site
http://www-307.ibm.com/pc/support/site.wss/MIGR-64283.html
i think it will solve this problem. Dont forget to install chipset drivers graphics drivers etc..
Thanks
mohan
Posted on Oct 29, 2008
SYSTEM ONE
  • 85 Answers
SOURCE: Wireless network connection on IBM Thinkpad
Ok when looking at your question i became very currious as to the answer myself so i did a litttle research and i think maybe the info on this page here: http://www.eggheadcafe.com/software/aspnet/33307589/certificate-required-to-c.aspx
could be of some use to you . even though the link describes a diferent network adapter the information there is about the same exact error on a router of the same type
I hope this information helps ... if it does not then let me know and i will find some more answers since i used to have the exact same laptop that you have now R40
Posted on Nov 20, 2008
SOURCE: IBM Thinkpad will not turn on wireless connection
1st go to MY COMPUTER, RH CLICK-PROPERTIES,HARDWARE TAB, DEVICE MANAGER,NETWORK DEVICES. CLICK ON THE + TO OPEN THE INSTALLED
NETWORK CARDS. YOU SHOULD MOST LIKELY HAVE 2 LISTINGS 1- YOUR ETHERNET PORT
2-YOUR WIFI CARD. THERE SHOULD NOT BE AN EXCLAMATION POINT OR A QUESTION MARK, EITHER INDICATING A PROBLEM. IF YOU DO HAVE EITHER LOOK AT THE DRIVERS 1ST AND THE ACTUAL HARDWARE 2ND. IF BY CHANCE YOU DONT SEE YOUR WIFI CARD
THEN TRY REMOVING IT AND REINSTALLING IT. TURN ON YOU COMPUTER AND SEE IF
XP RECONIZES IT "NEW HARDWARE FOUND". YOU HAVE TO SUPPLY A DRIVER FOR IT AS
WELL. GOOD LUCK
Posted on May 07, 2009
kamal1984
  • 1383 Answers
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 29, 2009
  • 8 Answers
SOURCE: I cant get a wireless connection on my IBM R40 using a Linksys G
I had the same problem with my R40 (2681) and a Linksys G router. The specs on IBM's/Lenovo's site indicate that the wireless card in the R40 only handles certain types of wireless encryption. The newer types (e.g. WPA) won't work on it and they are usually the standard on routers nowadays. My Linksys G router works fine with the R40 with WEP or with no encryption. Not ideal, but that's life with an old laptop.
Posted on Jul 26, 2010
Can't start my wireless modem
I think the problem is you cannot connect to the internet wirelessly using your laptop. The problem may lie in the modem or in the laptop itself.
First you need to isolate the problem. That is, determine if the laptop or your modem is the one that has the problem. If you can connect to the internet using your laptop in someone elses home network or free wifi outside your home, then the problem is your modem. BTW, modems don't have the capability to connect wireless devices to the internet. You need a wireless router. If what you have is a router, you're on the right track.
If your laptop can detect your home network, try connecting to it. If you're getting an error, call your Internet Service Provider. They should be able to help you fix the problem. Also, try updating the driver of your laptop's wireless card. You can do this by hardwiring your laptop onto your router, go to device manager, right click on your wireless card, then hit update driver. If nothing works, call your laptop's OEM.
Sep 28, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
I have an IBM Lenovo ThinkPad R60 laptop and the hard drive recently broke. I put in a new one and once i downloaded windows XP and stuff I could not figure out how to connect to wifi, can you help? The...
Welcome to Fixya
Make sure that all driver are installed. Especially the wireless LAN driver. Go to control panel then click on system then click device manager. Look for the network adapter category. There should be no exclamation mark to any of the devices listed there. You can download all your computer drivers here. If everything are ok then all you need to do is to go to control panel. Click network connection. Look for icon named Wireless then click on it. Search your router and connect to it.
Thank you for using Fixya!
Jan 09, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
Sony Vaio laptop unable to detect wireless access point
CompuLayne: Hello bluebells953
Netgear is quite tricky as is with all other routers, but I don't think the router is your problem. Try to do the following.
1) Turn off Vaio laptop
2) unplug router
3) unplug modem
4) plug back in modem - wait for it to boot up
5) plug back in router - wait for it to boot up
6) turn back on the Vaio - log in and see if it sees the SID. If it isn't broadcasting, you might have to enter it in manually and select connect to non broadcasting network
www.compulayne.com
www.compulayne.com : "We Fix Computers in 48Hrs! : We Are That Easy"
Feb 28, 2009 | Sony Computers & Internet
Thanks
mohan
Oct 18, 2008 | IBM ThinkPad R52 Notebook
Wireless Network Problem - IBM Thinkpad Lenovo R60
FN + F5 is normally starting your radio connection on Lenovo Think pad
Aug 12, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Drivers installation
u download from there
rate for me thx
Jul 30, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Motherboard
You can download drivers for IBM thinkpad R60 here: http://www-307.ibm.com/pc/support/site.wss/MIGR-64283.html
Hope it helps
cheers
Feb 14, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
IBM Lenovo ThinkPad R60 Notebook Logo
593 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
