Question about Acer TravelMate C110 Tablet PC
How do i change the cmos battery in a travelmate c110. The time and date and bios settings keep changing. Figure it needs a cmos battery. thanks
  • 6 Answers
The cmos battery is exactly located beneath in between the touchpad and speaker, it's a meticulous job, you could see a twin cable leading through the keyboard area. After removing the keyboard, cut the battery wires at the edge of the old battery and replace the new sealed pack by soldering its wires to the same connection. Be cautioned not to break off the slim edges of the keyboard sides by attempting to reach the battery while lifting up top silver panel from the front near the Infrared.
Posted on Apr 04, 2010
  • 100 Answers
Your cmos battery is around 3V..you just change it..
it is installed in the mother board just open and find it out it is like a tablet..
Posted on Nov 12, 2009
Where is bios in a acer travelmate c110 tablet pc
To access the BIOS Utility, press F2 during the POST (power-on self-test) while the TravelMate logo is being displayed.
Jun 23, 2010 | Acer TravelMate C110 Tablet PC
Why my acer travel mate c110 cannot touch screen ??? is it got a software to install it ? i go acer dun see any software for the Change tablet and pen settings. pls help me ~~~~~~~~~~~~~~~~
Try installing the drivers from the Acer website. The link is
http://support.acer.com/drivers_download.aspx
Select Notebook>TravelMate>TravelMate C110
Under the drivers tab, you will find all the drivers you need for your laptop. Don't forget to select the Operating system or else the drivers will not show up.
May 31, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
I have a acer travelmate c110 and I am trying to connect to a wireless connection but the wireless switch is not on and I do not know how to turn it on. Please help.
There should either be a physical switch somewhere on the side of the laptop or by using the FN + a certain key to activate it. Look at the F keys for an image similar to wireless then try that. If the above does not work, its probably turned off in the BIOS. Access BIOS and turn it on.
Mar 28, 2010 | Acer TravelMate C110 Tablet PC
Lost supervisor password acer travelmate c110
You could try booting in safe mode. Press F2 during Post startup to enter the set up utility. You can navigate to the Security Settings and change your supervisor password. You can find this info at: http://www.elhvb.com/mobokive/edwin/laptops/Acer/TMC110SG.PDF Pages 39-47 will walk you thru the steps.
Nov 25, 2008 | Acer TravelMate C110 Tablet PC
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Cmos battery for C110 TCI
The CMOS Battery is behinf the main battery behind a platic shield. The shield is relitivly fragile and glued around the edges. Care should be used removing it to prevent ripping. The battery itself is 3" flat pack glued to the case. Mine was wrapped in a black heat shrink with two wires exiting.
The connector is under the keyboard. You will need to remove the 6 scres from the bottom of the case to release and remove the keyboard. The keyboard ribbon cable is attached through a ZIF socket. Be sure and release the cable before removimng the keyboard. Youll have to trace the CMOS battery leads to determine the correct connector.
I found a Maxell ML2032 rechargable battery. Unfotunatly all the 3" flat pack batteries I have found are LITHIUM ION and not rechargeable. If I find a replacement I will post the information.
Apr 27, 2008 | Acer TravelMate C110 Tablet PC
C110 tablet
This is likely your CMOS battery dying on you and resetting your computer's date. Hitting F2 I belive it is will allow you to access your bios and on the second page you can see your date. It will likely be Jan 1st, 1988. Use your number keys to adjust the date and use your tab key to move between month, day, year, ect.
This is a temporary fix however and you will have to do this often until you have your CMOS battery replaced. I have a Travelmate that has the same problem.
Nov 08, 2007 | Acer TravelMate C110 Tablet PC
Acer TravelMate C110 Tablet PC Logo
1,336 people viewed this question
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
