Question about Nokia E63 Cell Phone
Hi there, I have a nokia E63. It currently has six application shortcuts on its home screen - I only need three ! It seems I can change what the shortcuts are but not get rid of them. How do I remove them altogether?
How to reset lock code for nokia e63? i forgot security code..
i think u better goto a mob service shop, and tell them to change ur phones software,or u do if u have a pc in your home(need net connection). While turn on ur mob after changing software ur current code is 12345
Feb 28, 2013 | Nokia E63 Cell Phone
My imei number is 359319022387949
Hi, What code are you asking for? If it is a security code, The default code must be 12345. If you have changed it and forgot it, Take your mobile to a Nokia Priority Store. They could do a master reset to your mobile. This would restore your phone with default factory settings.
If you need a network restriction code, You can get it from www.wickedunlock.com/nokia-e63/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR NOKIA E63
1 - Switch on your Nokia E63 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E63.
3 - Compose #pw+CODE+1#.
4 - The Nokia E63 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E63 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E63
Sep 28, 2012 | Nokia E63 Cell Phone
How to reformat Nokia E63
Hello there are two tricks that can format your E63.First type *#7370# when your phone is in stand-by mode (normal) and enter security code.Secondly,Format by press and hold three keys i.e. *(star),Green(call),3(three button)until your phone reboot in normal mode and power on the phone.Thanks for visiting fixya
Jun 20, 2012 | Nokia Cell Phones
I want new software for nokiae63
hello sir
you can find more software for your mobile phone in this links
1. http://nokia-e63-software.smartphoneware.com/
2. http://www.getjar.com/mobile-all-applications-for-nokia-e63/
3. http://www.mobileheart.com/cell-phone-softwares/1604-Nokia-E63-Software.aspx
Jun 02, 2011 | Nokia E63 Cell Phone
For a Nokia E63 from the home screen you can type the contacts name or part of it and it will show up. For some reason now when i type the name from the home screen it does not show up at all. i might...
From your home screen press any alphabet other than the one linked to a number (eg: W , Q, P) then go to Options > "Contact Search ON" which will turn on this feature.
Hope this helps. Good Luck ~SmokinJoe~
Apr 23, 2011 | Nokia E63 Cell Phone
How do i remove icons from my standby screen nokia 6700 slide they are no calender entries today and share your photos thanx
The only way to do it is to set the contacts bar as the standby theme (menu>settings>settings>general>personalisation>standby mode>standby theme), then go back into the standby mode menu, into Home screen applications and untick all the boxes. You are left with the shortcut bar along the bottom of the home screen, and nothing else. Nice. And stupidly complicated. Thanks Nokia.
Dec 27, 2010 | Nokia 6700 Slide Cell Phone
Hi i m ashish... i hve nokia 5800XM... my phone's some shortcut keys are not working properly...like shortcut menu bar....diller, contact key...call log by green button ..plz help me....
Hi Ashish
I am having a similar problem with my phone currently, it is a firmware issue that can be solved by doing a factory reset on the phone, however i am not doing it for now, because a new Firmware from Nokia has come for 5800 which is v40.0.005 and it is not yet out for the Indian phones so i am waiting to upgrade to this version.
Meanwhile to access the call log you can try this option, change the home screen theme to contacts bar from settings and then when you press the phonebook shortcut key or dialler shortcut key it would work
After you press the dialler shortcut key and you see the dialler on the phone screen press the green button it would show the call log.
Feb 04, 2010 | Nokia 5800 XpressMusic Smartphone
Unable to send sms as per detailed reason "General: Memory full. Close some applications and try...
just go to factory setting and restore settings it would start working fine. if u need the data then u take a back up from pc suite
Aug 17, 2009 | Nokia E63 Cell Phone
Nokia n95 home screen
I have tried to remove the vertical menu's while maintaining the horizontal shortcuts above, but it doesn't seem possible via the N95 menu. I'm sure there's a more extreme method, but that would be way too much of a pain....
Anyhow, if you would like to remove all of the shortcuts, here's the procedure (N95 non 8GB):
Settings -> General -> Personalisation -> Standby Mode -> Active Standby (OFF)
On my old N95, Settings are under "Tools" in the main menu, however, this may have changed on the newer versions. Although this may not strictly be the procedure for the 8GB version, hopefully it will help.
Cheers
Jul 21, 2008 | Nokia N95 Cellular Phone
Nokia E63 Cell Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
