Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
I have an etco chainsaw that will only start on the choke and stops almost immediately. The carb has been cleaned and a new diaphram fitted. A new fuel filter has also been fitted and spark plug. The spark looks ok. Can you please help me
  • 486 Answers
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
ChainSaws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Please double check the gasekts/diaphragms for proper installation
Posted on Nov 12, 2009
I have an efcoe137 chainsaw,that will only run on choke, cleaned carb and fitted new diaphram,checked spark and fitted new plug and put new fuel pipe but still won't run off choke
its starving for fuel. if you did all that you might replace the fuel lines, filter. may have to clean the carburetor again.
Feb 21, 2017 | Garden
Wont start, spews fuel out of combustion chamber, spark plug wet
sounds like the diaphram in the carb ..you will have to take carb apart clean and rebuild or just purchase new carb, I believe there are not to expensive, about 60 bucks..hope this helps..good luck
Sep 06, 2015 | Husqvarna 460 Rancher 24" 60cc Gas Powered...
Which is the correct way to fit diaphrams on stilh 450 carburators
Chainsaw carbs have two working sides, the pump side and the metering side, the pump side will have a diaphram and a gasket, the diaphram will have two small non return flap valves on it , it must fit against the carb body followed by the gasket, on the metering side the diaphram has a metal disc and a gasket, on this side the gasket goes against the carb body followed by the diaphram ( the gasket is used as a spacer )
Jan 15, 2014 | Garden
Older (early80s) 80cc jonesred wont stay started, It runs for a few seconds after i pull the recoil and only with the choke open the it stalls out
Fuel starvation, replace the filter in the fuel tank, check the fuel hose up to the tank for signs of leaks or cracks, if no better it will need a carb service, and clean the internal carb filter, as it is an old saw new diaphrams will probably be required.
Oct 05, 2011 | Garden
Poulan string trimmer cranks and runs fine as long as choke is on, release choke and use throttle no power shuts off
Fuel pump has deteriorated. Rebuild the carb. The engine pulses pump a small diaphram within the carb. Also little flap type check valves in the carb deteriorate. The alcohol in our gas now worsens the problem. The extra vacuum of the choke helps the failed diaphram. Rebuild kits, about $20.
Apr 26, 2011 | Poulan Garden
Carburettor letting to much fuel through.may be gaskets replace in wrong position
If you have dissmantled the carb and fitted new diaphrams, it is very important to re assemble in the correct order, starting with the pump side ( the diaphram without the disc in the middle ) the diaphram goes against the pump body, followed by the gasket, followed by the cover and securing screws, the metering side is the opposite, so the gasket goes against the carb body followed by the diaphram, followed by the cover and securing screws, the metering lever should be set level with either the sides of the carb body or the base of the carb body dependent on what brand of carb we are talking about, to service the carb correctly yoy should do a final pressure test with a bulb tester, the carb needle should hold a continual 2 psi pressure.
Mar 01, 2011 | Garden
Chainsaw high revs, floods, and dies when i let off the choke
its been standing all summer ,,,yes? you have a carb fault strip the carb and fit a new repair kit in it,
also clean out all the carb jets,,plus the tank filter
Dec 02, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Stihl chainsaw starts up but then it won't stay running. Changed spark plugs and tried new gas, but didn't fix the problem.
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Sep 05, 2009 | Garden
Idles with choke on - dies immediately with choke off
check air bleeds in carb next check exhaust port and pipe may be clogged as well as air intake
Jul 21, 2009 | 2002 Yamaha TT-R 250
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
299 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
