Question about Gaggia 102534 Espresso-Color Semi-Automatic Red Espresso Machine
I have power to the machine, but it's not heating up. Is this a problem that can be fixed?
  • 155 Answers
It can be fixed depending on problem and cost possible causes could be faulty thermostat fusible link blown heater blown or faulty wiring any of these could cause your problem you may have to have it servised letme know the outcome
Posted on Nov 12, 2009
HOW TO FIX IT WILKINS WASHING MACHINE WATER DOES NOT HEAT UP
If there's power to the element, then replace the element.
If no power to the element, check the relay or timer (most likely the relay).
Feb 13, 2015 | Washing Machines
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
My lavazza blue esspresso machine lb2200 displaying error-21
Power down, press and hold language button, power up and the machine should go through a rinse cycle and start heating. That is what I did anyway and the fault cleared .
Mar 01, 2013 | Coffee Makers & Espresso Machines
Fisher and Paykel smartdrive excellence 7.5
The pump has a thermal cut out fitted,
Pump must have over heated and cut power to machine.
Replace the pump to fix this problem.
Feb 04, 2012 | Fisher Washing Machines
Dryer won't heat. I just replaced the Thermal Fuse, but didn't fix the problem. Any idea's?
There are several thermal fuses in this machine but you will need to check the main power to the unit and make sure there is the correct amount power.Then you may need to check the heating element itself.
Feb 24, 2011 | Kenmore 659 Electric Dryer
Solis Crema SL90 NO HEAT
Hi
There can be a couple of things. The heating element could be bad. Check with an ohms meter. 12 - 16 ohms between the element terminals. You could have a bad power board. There is a solder connection that seperates and can be resoldered. Look for a small bulls eye where 3 solder connections make a triangle in the top left side. A little heat and new solder can fix it sometimes but don't put too much solder on or you will short the connections. If this doesn't fix the problem you need a new board.
Jan 21, 2010 | Solis Crema SL-70 Espresso Machine
JBP78 won't heat, breaker ok, stopped after auto clean
I need the Model # off the machine to help you.
Most comon problem with Electric range if The TOC or hi limit fuse after a clean cycle. This is usualy located in the rear of the machine behind the back pannel.
As always disconect the power to the machine befor trying to fix.
Jan 11, 2010 | GE Spectra JBP78 Electric Kitchen Range
Cuisinart 14 cup coffee maker won't heat up. It turns on but no coffee is brewed. heat plate is cold and water stays in resevior. Is it worth fixing? Can it be fixed?
It may be. Unplug the machine and take it apart. Find the thermal fuse. It is usually on one of the power wires near the plate. Check it with an ohmmeter or continuity tester. Replace it if it is open (no continuity) I'm not sure if they still do, but Radio Shack used to sell the fuses.
Jan 07, 2010 | Cuisinart DGB-600 Coffee Maker
Won't heat
The Breville esp8xl has a wire connector to the heat chamber that can become loose through repeated heat/cool cycles. Opening up the machine, finding this connection, which was loose, blue wire at back of heat chamber, and tightening it fixed my problem.
Aug 21, 2009 | Breville ESP8XL Espresso Machine
Machine error 77
the fuser unit (fixing unit) not registering heat requirement. The heat roller or the thermistor sensor is defective.Remove fuser and check roller, if good replace sensor, reinstall fuser and reset machine.
Aug 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Gaggia 102534 Espresso-Color Semi-Automatic Red Espresso Machine Logo
79 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
