Philips HTS3164 does not recognise some DVD's
  • 6,993 Answers
First clean the lens to be sure it is not dirty, but if the problem still occurs, then maybe your player was not meant to play for those DVD's.
Some players cannot play all DVD's, Because DVD' s are made with regions, so there are some players that plays all regions while some don't. Maybe yours falls under those that don't.
All the same be sure that the lens for your player is not weak.
I wish you the best of luck.
Posted on Nov 12, 2009
DVD8801 suddenly refuses to recognise most DVD discs
you could try to open the top cover and clean the lens with a clean soft piece of cloth and try to play before covering
Dec 16, 2011 | Philips Televison & Video
HTS3164 doesn't react to any controls
found the service manual here :www.2instructions.com
Jun 29, 2009 | Philips HTS3450 System
My philips dvdr520h dvd player does not recognise the DVD+R or +RW blank disc's
because there is no way to use that, if you look at the manual that dvd only rec DVD-R
Jun 04, 2009 | Philips DVDR520H DVD Player/HDD
Dvd drive dose not recognise any dvds i put in it keeps saying unknown disc
If your unit is older the optical pick up lens may be dirty or has gone bad. Most Philips units are exchange items only, meaning they replace it under warranty instead of fixing it, if its out of warranty there usually are no parts or service information on them. Philips was bought be Funai and is not the company it used to be. Check if the unit will play a audio CD, if it does the pickup assembly is bad, some will play a CD but not a DVD. You may be able to clean the p/u lens with alcohol and a Q-tip. The lens is under the clamp that holds the disc while spinning.
May 26, 2009 | Philips DVDR3320 DVD Recorder/VCR
My Philips DVD8421 burner will not recognize a blank DRD-R disc.
Ok, the reason is quite simple. The Philips DVD8421 does not recognise the DVD-R format.Not all DVD/CD burners read all discs. It does recognise DVD+R though. So all you need to do is use these discs instead. This should solve your problem.
Hope that helps.
Dec 05, 2008 | Philips (JR24CDRW99) CD-RW/DVD-ROM (Combo)...
Philips DVD+RW SDVD8820 does not recognise burned CD or DVDs
it could be upper and lower filters in registry and system files, use a removal tool called filtercheck 4.6 in CDR-zone.com (goto the forums and search for filtercheck)
after you downoad, run it, click yes to all filters found to remove. close program.
reinstall your preferred burning app (1 prog installed at a time and test burn)
this is to replace the filter entry that was corrupt
Nov 09, 2008 | Computers & Internet
Playing recorded DVDs on PC or other DVD player
Recordings from your DVD recorder should play on other DVD players as long as you finalize the recording on your recorder.
A PC should recognise an un-finalized, but only in a DVD writer drive.
There is a firmware upgrade available for this model. Follow this link and select your particular country version DVDR3320/XX
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dvdr3320v||page=1||show=50&xsl=search_result.xsl
Select Software & Drivers and click on the link to the zip file.
Follow the on-screen instructions.
Mar 02, 2008 | Philips DVDR3320 DVD Recorder/VCR
Philipds tv dvd combo
the problem is it is not with the tv itself the problem is with the dvd player the lens may need to be cleaned if you can message me i would be glad to help ya
Aug 08, 2007 | Philips 13MDTD20 13 in. TV/DVD Combo
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
