Question about Casio Exilim EX-Z77 Digital Camera
Battery not charging
Battery charger continues to flash red when charging battery??
5 Suggested Answers
Yazz226
  • 497 Answers
SOURCE: CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
Posted on Jun 13, 2008
walkietalkie
  • 32 Answers
SOURCE: battery wont charge flashing red
Every rechargeable battery deteriorates thoughout it's life of usage. may be it's time to buy a new one. Sometimes the terminals on the battery get in touch with metal things and short the circuits within.
Posted on Jul 12, 2008
SOURCE: Battery Charger Olympus li-40c
this appears to be a problem with cheap copy batteries. I've got the original Olympus battery that came with my camer and have no problems with charging i.e. the light comes on and stays solid red until the battery is charged at which point the light turns solid green. If i put in the cheap 'copy' batteries that I got off Ebay from China or somewhere, the led light flashes red continually, no matter how long I leave the batter on the charger for. I put the battery in my camera to check to see if it was charging at all and it has no charge in it. So I'm going to throw away the cheap battery I got. I think the flashing red light means that the charger is unable to charge that battery for some reason? Not sure why as I can't find any documentation on the net anywhere. Hope this helps some people.
Posted on Oct 26, 2008
SOURCE: problem charging battery
it your batter light is blinking a red light then you should call up casio's technical service and they'll send you a new one:)
call 1-800-435-7732 for technical support! :)
Posted on Dec 31, 2008
What does flashing red lights on the charger mean
Red lights on the charger means it is still charging.
Jun 28, 2014 | Parrot AR.Drone 2.0
Battery charger issue
funny thing with batteries is that they can get a memory = sounds stupid yes = if a battery is recharged when it has half charge and then fully charged it remembers the point , one it gains memory it wont charge past the last point = or the battery life is over = or the charger is faulty.
Jun 12, 2014 | Samsung S1030 Digital Camera
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Battery in charger overnight, red light flashing, insert battery in drill, it doesnot work. Please advise. Thanking You Bob Falzano
If only the red light is flashing then the battery is not charging at all. Ryobi identifies in the manual that batteries will not charge below 43 degress F. If your batteries and charger are in the garage in a cold climate, warm the batteries to room temp in the house and then try again. If the charge starts when the batteries are warm they will continue charging for the full cycle even in a cold area.
Dec 24, 2010 | Ryobi Multi-Volt Battery Charger
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
Should the red light on the battery charger stay on, even when the battery is charged? Or does the continuous red light mean the battery will not charge?
I am not familiar with this model, but most chargers have a flashing light as the battery charges, and a solid light when it is charged. Do you have the manual? It should tell you what the lights mean.
Jul 17, 2010 | Powerglide Power Glide Cordless Drill
Battery won't charge on casio ex-z77 exilim
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
Mar 26, 2009 | Casio Exilim EX-Z77 Digital Camera
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Casio Exilim EX-Z77 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
