Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon IR 3300 model - Paper Load Liver problem in second tray
Dear Sir I have Canon IR 3300 model. It has two Tray only. Now the second tray paper load liver will comes a sound on "tuck-tuck" including load & unload position. Print & Xerox also cannot come in 2nd tray. 1st tray and the free size will come print and xerox, but the sound also come. A new pick-up roller is changed in 2nd tray. Please Suggests. I wants your help quickly. Please do the needful.
Thanking you
R. Dhanabalan
Tamil Nadu. India.
  • 1,219 Answers
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Posted on Mar 02, 2010
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
Oct 30, 2016 | Canon Office Equipment & Supplies
I am using canon Ir 3300 it is lifting double and triple copy paper at the time of i made a copy. how to sole it. please tell me.
Clean all of your rollers with alcohol and make sure that your tray is loaded properly/not over loaded.
Nov 16, 2015 | Canon Ir 3300 Black & White Copier
CANON ERROR LOAD PAPER IN TRAY
There is no paper in the tray. You need to place the papers in the printer.
Aug 09, 2014 | Canon Ir 3300 Black & White Copier
Canon ir 3300
Try the following:
1) check for toner levels (may need new cartridge)
2) check for paper on the tray
3) try printing a copy from that device.
Dec 30, 2013 | Office Equipment & Supplies
Paper jam problem
Replace the paper pick up & paper feed & paper sep. rollers in the paper tray... Good Luck
Sep 01, 2012 | Canon iR 2016i Black and White Copier
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
Ir 3300 paper jam
the heater section is the fuser you should be able to pull the tray out and then lift the door of the fuser
Sep 03, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
1,235 people viewed this question
old marine
old marine
