Question about Midea Chest Freezer MCCF10WMD
I have a media dishwasher, it's new. works but
I have a media dishwasher WQP8-9325, not chestfreezer - not on list, it's new. works but water will not drain away. someone thought it might have something to do with hose?
  • 155 Answers
Possibly your drain hose is blocked maybe packaging or something if it is new did you have another one before this if not check you have drilled out the drain spigot under the sink if this is where you connected your hose let me know how you went
Posted on Nov 12, 2009
Where is controller knob on freezer
Brenda, haier freezer control quite often front lower right corner, some may be behind freezer by compressor, check the links to see if you can find your model and manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://image.haier.com/manual/southeastasia/haier/freezer/chestfreezer/201203/P020120309357074931017.pdf
Haier Freezer manuals
Haier Freezer controls Google Search
Jun 12, 2016 | Haier Freezers
What happens when the float switch is bad?
Hello;
My name is Peter. I am a retired field service refrigeration, appliance technician.
I think you have put your question in the wrong section this section is fro freezers. Freezers do not have a float switch.
So, lets assume you have a dishwasher. There are several reasons you keep filling with water:
1.) You may have a float that is restricted with soap film. This is a white bulb on the bottom of your unit. Remove the top and clean.
2.) At the top of your float is a contact switch. This switch activates you water discharge pump. This component is about $12.00 USD.
You can check this with a Ohm meter set to the lowest Ohms. Hold the switch button in and you should get a reading of '0' Ohms.
The above is just for your information. It is not your problem.
1.) Bad Water Supply Valve - Often the water supply valve becomes worn and blocked from age. When this happens you do not get the 65 PSI water pressure to close the water supply solenoid valve. Within your control system your float signals the valve to close. In your case it does not close.
Ok, lets check out your water supply shut off valve. With a bucket under the water supply valve, turn the valve off and disconnect the hose. If water comes out, then the supply vale is plugged and does not provide enough pressure to close the water supply solenoid valve on your unit. You have a bad water supply valve.
Ok, the water shuts off. Lets look at your unit water supply solenoid valve. The spool in the valve often becomes stuck with age.
With a hair drier gently warm the valve (NOT HOT) and gently tap the valve to try and loosen the spool.
This sometimes works. In the end you are going to have to replace the valve.
This is a pretty easy repair. The valve is about $35.00 USD. If I were to make a service call at your home, I would have to charge you $350.00 USD.
Send me your model number. It is located either on the face of your dish washer after you open the door or on top of the door.
Call me and I will walk you through this @ 443-306-1362.
I will be expecting a Christmas Card in return.
Glen Burnie, MD USA
Feb 28, 2015 | Freezers
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
Nov 11, 2013 | Samsung RS261MDWP - 26 cu. ft. Side by...
Water filter stuck
Is it the new one or old one stuck. You may have to loosen other things to get it out. There is not a lot of working room with these things.
Mar 02, 2013 | Maytag Amana / UKF8001AXX Swift Water...
Have installed new ice maker in a kenmore bottom freezer. Cannot get water to enter new ice maker to make ice.
You may have froze the water tube while messing with the new one. A quick fix with a hair dryer might do the trick. Also for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 31, 2010 | Freezers
5MONTH CHESTFREEZER WHICH WAS WORKING .PUT IT IN SOTRAGE FOR 3MONTHS NOW IT WONT FREEZE WHY CAN IT BE FIXED WHAT IS CAUSES IT NOT TO FREEZE NOW
I am having this problem also with my freezer not freezin after been unplugged for about 3 months, is it just stuck in refrost mode and if so what do I do? I has been plugged back up for the past 5 days and nothing but a hot freezer...yuck
Oct 02, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Ice maker not getting water
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
Aug 17, 2009 | Whirlpool Freezers
Manitowoc SD 0852A ice maker compressor will not kick-in
Here's my thoughts, I hope it helps. I'm going on foggy memory here, so I may not be entirely correct.
I worked on something like this a few years ago. The icemold (plate) is vertical, there is a circulating pump that runs water over the mold, with the water freezing as it passes. The sealed system is a heat-pump scheme, it freezes the mold to form the cubes, and reverses to heat for release. And when it works, it makes ice fast. It runs constantly until the ice hopper is detected to be full. (there should be a bail to detect the ice level) The system will not run in the event that it thinks the hopper is full (bail up) but the pump motor runs continuous to avoid it freezing. There is probably either a false detection of "full" or there may be a leak in the sealed system and the system will therefore not run.
Jun 28, 2009 | Freezers
Small puddle of water won't drain
make shure the strainer is clean
there could be a partial blockage in the pipe
make shure the drain pipe isnt kinked
Mar 18, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Midea Chest Freezer MCCF10WMD Logo
284 people viewed this question
Top Midea Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Midea Freezer Expert? Answer questions, earn points and help others
