Question about JVC AV-27D305 27" TV
Is it fixable
My JVC has a blue screen with lines running threw it with about 3 inches cut off the top and bottom. This is on all the video hook ups but they do have sound thanks.
    Scholar:
  • 168 Answers
Your tv has a problem with vertical deflection circuit. probably the ic or capacitors surrounding the vertical ic. have it check by a qualified technician. good luck
Posted on Feb 22, 2008
Dead Pixels on Sharp Aquos 70" LED TV
If pixels are gone on all channels - Exchange it
Can't fix it yourself unless you are tv technician
It is quite common for few pixels to be dead but that is usualy not noticable
Feb 06, 2012 | Sharp LC70LE732U LCD TV
I have a 2 inch line going down the middle of my screen from top to bottom. Would this be fixable?
Yes it is repairable. You will need to have the video board replaced. That line usually indicates an error in the video board.
Mar 23, 2011 | Sanyo DP50747 50 in. Plasma TV
Blue lines
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Feb 11, 2009 | JVC AV-56WP74 56" Rear Projection...
I have a 42 inches LCD TV and my son threw a hard object to it. It has lines from top to bottom and I want to know if it is fixable or not. Thanks, Claudia.
I'm sorry to be the one to tell you that once the screen is broken, is better to buy a new TV because the repair might exceed the price of a new one.
Sorry.
Aug 16, 2008 | Televison & Video
Blue line on the screen
Try hooking up an external monitor to the video adapter on your laptop. If the screen appears fine (no blue line) then your video card is good but you laptop's LCD monitor is bad. I would check eBay for a replacement. They are not too difficult to replace if you are somewhat mechanically inclined (can unscrew some screws and disconnect a wire plugged in the motherboard).
hope this helps! : )
Jun 04, 2008 | IBM ThinkPad R52 Notebook
JVC AV-48WP30 started displaying vertical lines every inch
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
May 13, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 has vertical lines every inch or so...
This may not be the problem but its worth a try:
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Sep 24, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-27D305 27" TV Logo
55 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
