Question about Olympus DS-2300 Digital Voice Recorder
I cannot record. Read only card is displayed.
    Guru:
  • 480 Answers
YOU NEED TO FORMAT IT .
CONNECT IT TO A PC AND FORMAT THE PEN DRIVE
BE SURE TO CHOOSE THE FILE SYSTEM FAT WHEN FORMATTING
Posted on Nov 12, 2009
  • Kasey Johnson Aug 13, 2011
    Also make sure the "protect data" switch isn't in the wrong location on your memory card. If this little plastic piece is missing, simply tape over it with masking tape (tiny piece should do it, just don't tape over the copper connections on the card) and the camera will use it again just fine. I've been doing this with a card of mine for over a year now, no problems!
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Jul 16, 2012 | Mitsuba DV777 Camcorder
Can I recover voice files from my SIMS Model SVR-S825 Digital Recorder? I left the unit on and it maxed out the memory and battery. When I replaced the batteries, no files were displayed. The recorder...
Download and install Recover my files utility ->
Click here to Start Download
Determine what kind of connection cable your digital recorder uses, such as USB or FireWire. Connect the cable to the corresponding port on your computer.Open the file recovery utility. Click "Settings."Click "Save Recovered Files To." Select the location where you want the recovered files to be saved, such as a folder on your computer's hard drive or back on the digital recorder.
Click "Advanced Scan." Click the drive letter that corresponds to your digital recorder and then select "Next."Scroll through the list of available file types that the utility can recover. Click the check box next to the type of deleted file you are searching for, such as audio,click start.
Recover my files guide
Jul 29, 2011 | Sims Audio Players & Recorders
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
I have a Sanyo Xacti FPC-FH1 with a 32g SDHC card. I can only get 4g of recording time. The recordings after 4g have a big" ? " in the display when I list the recordings in playback mode, and while...
You could plug the card into your computer using a card reader and then right-click on it. Click on properties and it will give you the used and unused space.
Jun 27, 2010 | Sanyo Xacti VPC-S60 Digital Camera
Can't read SM 128 card on Vista or XP
The solution was that the SmartMedia card I was using seems to have been corrupted. It works perfectly well in my device to record music, but cannot be read through either of my computers. However, another SmartMedia Card does work and I have been able to download files, so it must be the card. The manufacturer of the MRS-4 recording device, ZOOM, say that they know of no way to repair the corrupted card.
Best wishes,
Nov 15, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
Laptop built-in sd card reader won't read
i think your sd card reader has damage and you need to change it
i hope i can solve your problem
Aug 25, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Olympus DM-10,locked in a "Read Only" mode
The recorder should be formatted only by using the internal FORMAT function found in the recorder’s Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended.
Apr 10, 2009 | Olympus DM-10 Digital Voice Recorder
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Will not record to card- read error!!
TRY A SMALLER CARD SEE IF THIS HELPS.. THIS MODEL DONT ACCEPT ALOT OF MEMORY
Dec 14, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Smart media card
These recorders can only read the 4MB and 8MB cards. Good luck finding those smaller cards.
Oct 03, 2007 | RCA RP5007 Handheld Digital Voice Recorder
Olympus DS-2300 Digital Voice Recorder Logo
454 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
