Question about AT&T Siemens S46 GSM Cellular Phone
Hello My Siemens extra klasse WM14S790FF
Hello My Siemens extra klasse WM14S790FF displays blocked pump and does not drain.
I have followed the book procedure for draining the pump manually and cleaning the pump filter compartment which hasn't helped.
The outlet pipe does not appear to be kinked or blocked and I don't think the outflow drain is either .
Any advice would be greatly received .
Sid Kosmala
  • sidzeena Nov 12, 2009
    I was referring to a washing machine not a cellular phone hence a blocked pump .
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
My siemens washer front loader is displaying an E04 what does that mean
Drain is blocked - unplug the auxillary drain plug and check for clog.
Mar 21, 2014 | Siemens WXL142 Front Load Washer
Getting a E04 error code
According to siemens website Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book. Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens WFXD5200UC Front Load Washer
Dear my washing machine is product from italy made siemens wash and dry its showing E14 errorr please advise me what i can atcvally
Dec 09, 2013 | Siemens Washing Machines
The pump is not pumping water when in drain cycle and "Pump Blocked?" error is displayed. The washer has been drained and the pump cleared of debris (penny, toothpick and two small rectangular...
Hello & Welcome to FixYa
If you have cleaned it completely and nothing is blocking the drain pump assembly then it means that the drain pump is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jul 25, 2011 | Bosch Axxis WFL 2060 Front Load Washer
F2 error code flashes and machine wont finish the drain cycle
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
Dishwasher siemens is not draining water.
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Siemens WFXD8400UC Front Load Washer
My Siemens WFXD8400UC won't drain; I have checked the hose and nothing is blocked as far as I can tell. Any suggestions?
Hello, welcome to FixYa.
You mentioned you checked the hose, yet based on your description it sounds like a pump isse.
I would start by checking the pump for lint or other debris which may prevent it from draining properly.
**Unplug the washer from the wall or turn off the breaker at your service panel...safety first**
Here`s how...Start by removing the bottom front panel which provides access to the drain pump and manual door lock release.
1) Carefully lift and block (up with a 2x4 or egual block of some type) front of washer to provide access to screws along the bottom which are angled slightly.
2) Remove three (3) screws, then carefully slide panel down and away from washer.
3) You should now see the pump access filter to your right, as such...
4) The pump has a small tub connected to it which will allow you to try and drain the water from it before removing the filter.
5) The filter will unscrew counter clockwise...careful it likely has water in it. This is where a wet-dry shop-vac comes in handy....or a nearby floor drain.
6) Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
7) After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
8) Run a load and watch for leaks. Leave the pump access panel off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
Aug 17, 2010 | Siemens WFXD8400UC Front Load Washer
My Siemens Hydrosensor dishwasher seems to go through the entire cycle but at the end mainly the top rack of dishes, sometimes the bottom rack is completely covered with a film of junk. It ends the...
It is obvious the drain or pump out is not working. There is a blockage in the outlet. Check the drain under the sink nby removing the hose and making sure the hole is not blocked. The pump in the dishwasher may be blocked. fixing this may not be within your field of expertise and a technician may be needed. Good luck
Jul 31, 2010 | Siemens 24 in. SE53200 Built-In Dishwasher
Display reads "pump blocked"
TURN OFF MACHINE AND UNPLUG THEN DO THE FOLLOWING:
Open the pump filter cover:
23294f2.png Remove and uncap drainage hose to empty detergent and then replace the cap.
Unscrew the filter and clean it, inspect the filter cavity inside the machine for matter that might be blocking it. Check the waste hose that leads out of the machine to see if there is a restriction somewere.
Oct 15, 2009 | Siemens WM14S794GB Front Load Washer
AT&T Siemens S46 GSM Cellular Phone Logo
156 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
