Question about Canon MultiPASS F80 All-In-One InkJet Printer
Scanner error ( Scanner light dosen't turn on)
  • 97 Answers
It will not turn on properly if you haven't install it properly.
Posted on Feb 28, 2008
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Red error light on vupoint magic wand scanner
Viewpoint scanner manuals are available for download: http://www.vupointsolutions.com/downloads.php?d=manuals
Unfortunately I still can't get my red error light to turn off!
Jun 28, 2012 | VuPoint Office Equipment & Supplies
Comunication error with 796d and computer.there's no serial port on my computer, so im using a rs-232 to usb. dosen't matter what usb port i use on computer, it still does not work. im using the...
  • Hi, I can help.
  • This happens a lot to people just setting up a scanner like this. Try these suggestions, I think you'll be up and running in no time.
  • You have to make sure the BAUD rate is set and make sure your PC control is turned on in your scanner. A BAUD is the rate per second data is sent.. A BAUD rate of 38400 (or what ever BAUD the software is at). I think parts 3,4 and 5 in the your scanner menu cover this. If you have the FIFO buffer set then remove it from your settings > control panel > comm ports. You will get the best results if you have that software read the bank before writing to it. Relabel your comm port settings if you need to as well ie. port 1, port 2 etc.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa,
Regards, Tony
Sep 21, 2011 | Uniden BC796D Base Scanner
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Turns over but wont start. 1997 chevy 2500 4x4
Check to make sure that the grounds are good on the engine...the scanner error could be that...and does the service engine light come on when you turn the key to run position? If not, I would take a close look at the PCM.
Oct 29, 2009 | 1997 Chevrolet C/K 2500
Modle 5222, scanner error?? any suggestions?
sure you lamp lights up when machine is powered on. open the top cover, turn power on. lamp should light and scanner should move. if either of these do not happen you will need to replace parts. if the lamp lights and the scanner moves your ccd could be bad. you may need a service tech. if the lamp does not light it is your problem. lamp, power supply, ballest, or main pcb could be the problem
Oct 21, 2009 | Lanier 1205 Copier
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
Hp laserjet3030 is put on it shows" Scanner Error"
Hi ritaccpl: Here is your problem. 52 Scanner Error The all-in-one has experienced an internal hardware error. 1. Turn off the power by using the power switch, and then wait at least 30 seconds. 2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket. 3. Check the FFC connection between the formatter and the scanner. NOTE Do not bend or fold the FFCs during the removal or reinstallation process. 4. Try connecting the product to a different power source or surge protector. 5. Turn on the power and wait for the all-inone to initialize. 6. If the error persists, replace the laser scanner assembly. Hope this helps
Jun 08, 2009 | HP LaserJet 3030 All-In-One Printer
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
Canon MultiPASS F80 All-In-One InkJet Printer Logo
old marine
old marine
