Question about Biostar : U8668D P4/DDR/FSB 533/A&V&L/ATA133/MATX Motherboard
I can't connect my pc with another pc by LAN cable.After connecting my Lan cable it gives me no signal by the led which is connected with the hardware.it always show the network cable is unplugged.
  • 691 Answers
Is the cable a crossover cable
You need a "crossover lan cable" to conect PC to PC
A "lan cable" is for networks
Posted on Nov 12, 2009
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
Lan cable not connected
Try re-connecting the LAN cable to your computer and the model/router/
If this does not work the try a different LAN cable - the cable could be faulty.
May 02, 2012 | Sony VAIO E Series VPCEB36GX/BJ Notebook
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
The lan ports do not work but the wireless works fine.
I think that the router is just fine.
The issue could be with the LAN card of your PC of perhaps a faulty cable. So, my advice is to check the cable and lan card of your PC. You may use a different/already working cable and a laptop for diagnosis. Note that status of LAN connection is indicated by the LEDs at the front of router and LAN connection of the PC. If the LED indicates connection, then it could be the configuration issue.
Hope this helps!
Let me know if i could be of any further assistance.
Nov 12, 2010 | Linksys WAG325N Router (WAG325N-AU)
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
LAN not working,i mean that LAN led not blinking.and i fail to connect internet connection.Plz give me suggestion....
try unplugging the cable and insert again ...
check if any lose connection ............... install your lan s/w properly ........
Feb 09, 2010 | Intel Motherboard
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
ASUS P5RD2-VM MOTHER BOARD - lan port is not working not showing led on lan port jpshah j5p10shah65@yahoo.com
You have to install lan card driver to show your lan connection.
Check the cable is connected both end properly and other end pc is connected modem or switch is turned on.
Aug 26, 2008 | ASUS P5RD2-VM Motherboard
WAP54G bricked power led blinking LAN connection shows as not connected
you did not specify where the wap is connected when you pinged it. Try this, connect the wap54g to your pc. Assign static ip 192.168.1.5 on the lan of the pc, then ping 192.168.1.245. if you can ping you should be able to access the configuration page. if the power is still blinking you can upgrade the firmware
Mar 10, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Biostar : U8668D P4/DDR/FSB 533/A&V&L/ATA133/MATX Motherboard Logo
79 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
