Question about Garden
I have a little giant pe-a pump and need to know what wire is hot nutral and ground so i can re wire
Hot=black
nutral=white
green=ground
unless you are rewiring plug end pump should be disgarded for safty sake
Posted on Nov 19, 2009
Two black (positive) wires, one ground wire. No neutral. How is it hooked into 115 circuit.
Actually the green should be ground, one place is phase and the other is neutral. If the Green / ground wire is not connected correctly you have a shock hazard in water.
Sep 03, 2013 | Little Giant Magnetic Drive Pump - 1-AA-MD
Gfci keeps tripping
if a pump connected to a gfci brkr is tripping it , gfci has detected a connection from hot wire to ground !! this could be a high resistance connection still allowing pump to run but "leaking" power to ground thru restance connection , this pump could become dangerious (if short gets worse) and should not be used for this application
Jul 12, 2013 | Little Giant Garden
How do I wire the AquaPro 600 correctly? Do I need 3 or 4 wires> L1 and L2 Hot, Ground and Nutral or just the 2 Hot and ground?
Depends. L1 and L2 would indicate two hot wires. Definitely need a ground. I would pull a white just because. Is there ANYTHING in the device that operates on 110 - if yes, you will definitely need the neutral.
Sep 04, 2011 | RTO Aqua Pro Systems Pro 600 60,000 BTU...
I installed a shur-dri 4"
Hello
If this is a 220 volt pump then it needs to have 2 hot wires,so it would be connected to 2 15 amp breakers.The ground shold run from the pump back to the fuse panel box ground bar.
If this is a 115 volt pump it should be connected to one hot, one nutral, and one ground.
Possible a hot wire is making contact with water and tripping breaker.Or the pump motor is going to ground which means its no good.
Aug 01, 2011 | Heating & Cooling
How do I wire the safety overflow switch to my furnace humidifier thermostat? I have a Little giant VCMA-20ULT and a Aprilaire 700.
The overflow switch needs to be wired in a manner that interrupts the HOT (black?) side of the wires going to the water inlet valve or it's circuit.
Feb 28, 2011 | Little Giant VCMA-20ULT 80 GPH - Automatic...
My little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
Jun 25, 2010 | Little Giant SPS25 Water Removal System...
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
How do you wire a 2 wire Franklin 1/2 HP 10 GPM
you can just install a regular plug to the end of the wires and plug it in,, but you will need to add a ground wire,, if there is only 2 wires there should be 3 so look for a screw with a spiral clasp on it for the ground,,
Apr 21, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
