My Pc Activity light in constantly blinking and my
My Pc Activity light on my Modem is constantly blinking and my internet connect is working only once in a while, and is really slow.It just started doing this after 4 months of working fine. On the Router itself, the Power light and the Connection light are blinking too, and that didn't happen before I think.
  • zero_army_69 Nov 12, 2009
    Thanks for your comments. One thing I forgot to mention, I have 4 other roomates, and it's the same problem for them. Should I still Get those apps to see if it's a bug?
  • 37 Answers
Sometimes something as simple as resetting you router or cable modem will fix this problem. Turn the power off to your router. Leave it off for 10 minutes with the network cable disconected. Then plug cable back in and turn it on. To reset a router, there is usually a reset switch in the back. You will need a small pin or unbend a paper clip. Press in the reset hole. Hold for 2 seconds for most routers, I have seen some that told you to hold it for 10 seconds. Also make sure all cables and plugs are fully seated or connected. Please let me know if this doesn't correct your problem. There are other things that it could be, but a good reset helps to minimize electromagnetic interferience.
Posted on Nov 12, 2009
  • 691 Answers
Router, depend on the model but it sounds ok
try 2 things - sounds like a bug
turn off system restore
google & download
  • combofix
  • dailafix
run both of these and then restart
turn on System restore
I think you should find it faster now
Richard
Ethernet light blinks continuously on my bigpond wireless. Does that mean there is a problem?
A constant blinking Ethernet activity light indicates that the computer is transmitting and/or receiving information from the internet or other network devices. It's nothing to worry about. The light may be constant only when we are setting up the modem.
Regards,
Shrey
Jun 01, 2011 | 2wire (1000-000057-000) Modem
How to confirm that the BSNL modem is having problem & cannot be used any more if INET light is continuously blinking?
There are several lights on your modem/router. Each one has a function and signals whether it is working correctly by the color it is displaying and a few other factors.
All of the lights on your modem/router should be green and solid - EXCEPT for 2 which are for your internet and wireless services. Blinking means activity. If you INET light is continuously blinking that means its healthy. Blinking means activity. The internet always has activity. The blinking does not signal your activity - it signals the traffic and connection on the internet. Your wireless connection also has a light which should show activity and availability. A blinking light on your wireless connection means that either someone is connected wireless and using the internet or that the connection is up and available for wireless access.
All of your lights should be green. If you see a red or yellow light - regardless of whether it is flashing or not - it means that there is trouble or problems that need to be corrected.
Each light is marked with its function. They should say things like "power", "link", Internet or INET, and "wireless". When you turn on the modem/router during your first set up, let it power up and finish its testing before connecting your pc and turning it on. The modem will test each light, make them all go from red/yellow to green - then make them all turn solid green (not in that exact order) and this is all normal. You will know when it is done when all lights are solid green and stop blinking and/or moving (except the INET & wireless lights which will be constantly blinking). When all lights other then those two are green and steady - then its time to connect the cable to your pc and power it up.
If you are having problems with your internet connection - you can rule out the cause being your modem/router by following the instructions above. When you rule out that the modem/router is not the cause, you can continue by checking your PC.
For a wired connection (wired meaning that you are connecting your computer to the internet by using a cord/cable) the first thing you want to do is make sure that the computer is automatically sensing the connection.
Your computer should automatically sense that there is a live internet connection when you connect the ethernet cord from the modem/router to the pc. When its working right, the computer will display a connection picture which is called an "icon" on the bottom right side of your screen near the clock area. Sometimes there is a downward arrow by the clock which needs to be clicked on to expland this area and show all icons for running programs. If you see a downward pointing arrow by your clock on the bottom right side of your screen, click on the arrow.
Test that it is sensing the internet connection by unplugging the ethernet cable from your pc and watch the bottom right side of the screen at the same time. Unplug it and repeat if necessary while watching the bottom corner to see a change which indicates it senses the connection. A normal internet connection icon looks like the picture of a computer monitor. Some glow green when they are active and the ethernet cable is connected. Some show a red "X" over the picture of the monitor on the bottom right side of your screen when the internet connection is down or not working. Some will say "cable disconnected" when you unplug the ethernet cord. Some show "Cable now connected" when you plug it back in. You should see something change and/or appear if your pc is picking up the internet connection correctly. When you have verified this as true - then you can continue on to the next step of troubleshooting the internet connection.
DSL service is an internet connection that is always on. Its considered a "live" connection. DSL connections usually do not require any set up (programming or changing settings). The only time that this is not the case is when someone tries to to set up a dial up connection like aol over the top of a dsl connection. You can check this by going to your control panel, click on internet options, and choose the "connection" tab at the top. In the connection area box there should be "nothing". The connection area box is for dial up connection settings. If a dial up service was set up in the pc it would show it here (you would see AOL dial up ect). If you see a dial up connection set up and you know that you have dsl, click on the remove box and delete it from this area.
You do not need to install anything from a disk to establish an internet connection if you have a dsl line. That means you dont need an "aol" disk or software to make the internet work.
to start the internet click on the blue "e" on your desktop which stands for internet explorer.
If you have any questions you can reply to my solution by going into the problem you posted on Fixya and click on the "reply" option.
Mar 03, 2011 | Samson Technology X6v ADSL ModemWireless...
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
My modem randomly resets and no internet.
either the modem is going out or its a problem with your internet provider. before calling to complain to the internet provider. run down to your local walmart or electronics store and pickup a modern if you have the same issue its your internet provider.
i delt with a modem that was causing a similar issue. the problem ended up being the modem was running hot. i modified the case and added an external fan and the problem went away.
hope this helps. good luck
Mar 03, 2017 | Thomson RCA DCM245R Modem
My Motorola Sb5101 modem will not let me access the internet, the send light constantly flashes and i can't attain any internet connection.
If you have the following lights :
Power light - on
Receive light - flashing
Send light - flashing
Online light - off
PC/Activity - on
Standby - off
Then your Network Access is OFF - modem is successfuly registered but Network Access Control is disabled via DOCSIS configuration file.
Call your internet service provider....
Nov 06, 2009 | Arris SURFboard SB5101 Cable Modem
The power light and PC activity light are the only lights that come on. Send/Receive lights don't blink.
the most easy way to connect to the internet is get a bluetooth connetion (zippys) press the tools find device on the bluetooth on ur phone press pair device and press dial up inthe username put ur mobile number and password mobile number dial up number *99# dial
Apr 28, 2009 | Arris SURFboard SB5120 Modem
Constantly blinking Activity light
Well, you are very correct with the activity light blinking and the increased blinking except the fact that modem will encounter a problem in future...
The 5 different lights on your modem namely Power, Ethernet, DSL, Internet and Activity have their own indications and explanations.
1. The Activity Light indicates the amount of activity that is takin place on the computer on the Internet though the activity might blink even when you are not browsing. This can be explained by stating that the computer constantly keep sending signals  about it being connected to the internet and any other acknowledgements..
So, you've got nothing worry about unless the Power or the Ethernet or the DSL or the Internet light Blinks....
Cause they are the resultants of a fried modem(check for the adapter), faulty LAN connections, interrupted Dsl line and the account verification failure indications respectively.....
Dec 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Activity light is is constantly on.
if the activicty light was off then that would mean you werent connected to the internet thats what kind of activicty it means, its the internet activicty
Dec 31, 2007 | Arris SURFboard SB4200 Modem
Netgear fr114p constant activity problem
Have you looked at the traffic logging information from your FR114P? You might want to visit http://www.LinkLogger.com and download a copy of Link Logger for your firewall and see what your firewall says is hitting it. Do You have UPNP enabled in the router ?
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
345 people viewed this question
David Payne
David Payne
