Question about RIM BlackBerry Bold 9000 Smartphone
There is a number "3" next to a globe with an arrow pointing diagonally across
  • 541 Answers
There is weblink in a message
If there is a weblink in a message you get this changes on the device
You can delete the message
Posted on Nov 13, 2009
What are the diagonal chassis measurements for a 2007 toyota hilux
you will get these from a toyota dealer from their workshop cd manual. However if you want to check the chassis for bends , the dimensions do not need to be known
place the vehicle over a flat floor and using a plumb bob on a sting line drop points onto the floor and mark the position on the floor . Use the same points on each side of the chassis
get as many marks on the floor as possible and put on the floor next to the mark where they came from on the chassis (ie rear spring hanger, foot step bracket , tank bracket etc)
move the vehicle out of the way and with a tape measure measure the diagonals of like points. Write the dimension on the floor on that diagonal. When finished the variations of like diagonals should be no more than 3mm max. The diagonal with the largest variation will indicate exactly where the chassis needs straightening
Dec 23, 2014 | 2007 Toyota Hilux 2.7
Tip
To open watch case, hold back of watch up with arrow pointer on the back plate...
If you don't have the proper watchmaker's tools (and you'll need several!) I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you. Most Sears stores will do it while you shop.
on Jun 05, 2010 | Watches
What is a polygon with 15 diagonals
For convex polygons there is a relation linking the number of sides to the number of diagonals. Here it is, with n=number of sides
number of diagonals=n*(n-3)/2. Obviously the number of sides must be greater or equal to 3.
If you use the relation for a hexagon (n=6) the number of diagonals is 9. With n=7, the number of diagonals is 14, and for n=8 the number of diagonals is 8*(8-3)/2=20. The answer is that there does not exist a CONVEX polygon with 15 diagonals.
You can also try to solve the quadratic equation n(n-3)/2=15 for a positive integer. And you will not find a solution.
For polygons that are not convex there may be many solutions or no solutions. I leave that to you as an exercise.
Mar 11, 2013 | SoftMath Algebrator - Algebra Homework...
Globe access point
APN: Go to MENU, SERVICES, DATA ACCOUNTS, GPRS, create NEW SETTINGS.1. if your globe sim card is not yet activated for inet, then configure it manually.. go to connectivity then go to access points, make a new one and name it Globe inet..then on the APN put this "http.globe.com.ph" without the "
2. then after that, go to internet profiles, make a new profile and name it globe inet.. name it Globe inet. then choose to use a proxy.. then enter this proxy address "203.177.91.131".. and then it the proxy server port, put "80".. then on the access point choose Globe inet..
3. now you need to make another internet profile.. so make a new one. name it "proxy".. then choose to use proxy, and then enter this proxy "195.189.142.132" then on the proxy server port put "80"..then on the access point put Globe inet..
4. ok now your done configuring your globe inet settings,. next step is to go to games and apps, then choose settings, then choose profiles, and add profile.. name the profile "proxy". then on the internet profile choose "proxy" then save it and activate it..
Feb 14, 2012 | LG Cell Phones
How to set the gprs of n-gage qd???
  • Go to Menu > Tools > Settings > Connection > Access points > Options > New Access point > Use default setting. Enter details for the following options
    • Connection name: myGlobe GPRS
    • Data Bearer: GPRS
    • Access point name: www.globe.com.ph
    • User name:
    • Prompt password: No
    • Password:
    • Authentication: Normal
    • Homepage: http://www.globe.com.ph/globe.asp
    • Gateway IP address:
    • Press Option then select Advance settings. Enter details for the following parameters:
      • Proxy serv. address: 203.177.42.214
      • Proxy Port Number: 8080
  • Go back to the main menu, select Services, Options then Settings. Choose myGlobe GPRS as the default access point.
  • for more help u can use this link :http://site.globe.com.ph/c/document_library/get_file?p_l_id=24310&folderId=36798&name=DLFE-421.pdf
    Feb 11, 2011 | Nokia Cell Phones
    Entering coordinates
    When you press on your Where to? graphic a menu will come up that will give you a number of choices including
    Address, Go Home, Points Of Interest, and 3 others. There should be an arrow point down in the lower right corner of the screen. When you press that the screen will scroll down a page and you should then see the Coordinates Globe. Press this and the screen should change to the Enter Coordinates screen. This will allow you to enter two sets of coordinates for your destination.
    May 29, 2010 | Garmin Nuvi 350 Car GPS Receiver
    Diagonal lines on upper 1/3 of screen
    It sounds like the dmd board may be defective but you can try rebooting the set and see if it makes the picture any better...
    1 - Turn on the Tv.
    2 - Press & Hold the up arrow key on the remote and then press the power button on the front of the Tv.
    3 - Tv will reset & reboot
    If the picture is the same it's probably the dmd board which is part of the "B" block assembly and I don't believe they're sold separately. The "B" block is about $1100.00 dollars.
    Hope this helps!
    Bill
    Apr 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
    Line 3 and 4 are not programmed
    You need to go into main programming of the system, and set the phone to access those lines. First ID the 2 new extensions. Do this by going to the phone, and pressing the Feature Key "Button with a little black globe", * and 0. then press the intercom button. This will show you the extension number. Press release "Red button with the phone and arrow downward". Then Press feature key "Button with the black Globe" "**266344" and again "**266344" go to terminals and sets. next to the buttons, you will see triangles , 3 for a while and 4 some times. The keys just next to them are your scrolling and enter keys. Scroll to "Terminals and Sets", press the enter button "Top right triangle" and enter in the extension and enter. then scroll to Line Access, enter, line Assignment. For each line, you have to change it to either Appear and ring, appr or unassigned. Set to appear and ring or appr. Do is for each extension to want to have acces to those lines.
    Apr 27, 2007 | NorStar BCM-M7324 Corded Phone...
    Diagonal lines on print
    Follow these steps.
    Print Quality Problems on 3010cn.
    Reset the NVRAM On the 3010cn
    To reset the NVRAM, perform the following steps:
    1. Press the Menu button.
    2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
    3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
    4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
    5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
    6. Power off the printer and power back on.
    To print the Gradation [ESS] test print, perform the following steps:
    1. Power off the printer.
    2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
    3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
    4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
    5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
    To print all four 20% toner test prints, perform the following step:
    4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
    5. Press the return%20arrow%203100cn.jpg button. The test print will print.
    6. Press the Cancel button.
    7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
    8. Press the return%20arrow%203100cn.jpg button. The test print will print.
    9. Press the Cancel button.
    10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
    11. Press the return%20arrow%203100cn.jpg button. The test print will print.
    12. Press the Cancel button.
    13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
    14. Press the return%20arrow%203100cn.jpg button. The test print will print.
    15. Press the Cancel button.
    16. Power off the printer and power back on.
    Reseat the drum cartridge, perform the following steps:
    2. Unplug the power cable.
    3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
      Figure 1 - Open Front and Top Covers
    4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
      Figure 2 - Raise Lever to Release Drum Cartridge
    5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
      Figure 3 - Remove Drum Cartridge
    6. Insert the drum cartridge.
    7. Close the top and front covers.
    8. Plug in the power cable.
    9. Power on the printer.
    Apr 11, 2007 | Dell 3100cn Laser Printer
    RIM BlackBerry Bold 9000 Smartphone Logo
    43 people viewed this question
    Top RIM Cell Phones Experts
    Longtime User
    ismael castillo
    Jason
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
