Question about Garmin nuvi 250W GPS Receiver
Same as posting Sep 12 09 - stuck in mass storage mode when connected to anything - charger, computer, car. Works fine on battery power
  • 1 more comment
  • john_alle57 Nov 12, 2009
    Had Nuvi 350 2-3 years. It has been replaced once by Garmin under guarantee when the sound failed. Now out of guarantee. I have tried resetting but it doesn't do anything.
    Could it be the battery?
    Regards,
    John Allen
    When the unit is connected to a switched off socket outlet it works normally on battery power, but when socket is switched on it goes straight to the mass storage screen then back again to working normally when either the socket is switched off or the cable disconnected.
    Garmin Nuvi 350. Works fine on battery power but when connected to a wired power source, whether in car, home charger or computer USB, shows the mass storage screen and I then can't use the device. I have tried the reset button on the back of the device but no luck
  • 4,806 Answers
In some cases it's simply the wrong lead that's being used in the car. If you use the original lead you may find the problem resolves itself.
You also may need to reset the unit, but if you do this all user data will be wiped.
With your nuvi powered off, press and hold the lower left corner of the screen. Next, turn the power on. Continue to hold the screen until it asks if you really want to enter maintenance mode. Next, choose clear user data. The screen will flicker a bit and then start up like it did when it was first turned on. Follow the directions to set time and location. You will have to reacquire satellites by turning on your nuvi outside in full view of the sky. This one time acquisition may take up to 30 minutes.
Good luck.
Posted on Nov 12, 2009
  • 4,472 Answers
How long have you owned the unit and how long have you had this problem? Once I get more information i can assist you. Also have you tried performing a reset?
Thank you,
Lee
  • Lee A.
    Lee A. Nov 12, 2009
    Also if you turn the unit off and you plug in the charger what does it do? Also how long have you had the problem? If the problem persists I would just work around and get your moneys worth out of the device. If you need any further assistance please let me know.
    Thank you,
    lee
    Top Expert:
  • Garmin Master
  • 75,807 Answers
Have you tried a system reset? the reset button is on the bottom of the GPS, it has a decal over it marked Reset, with a kind of bulls eye circle over the recessed reset button, u use a straightened paper clip to push the recessed reset button, if that doesn't work u will have to have Garmin fix it, there are no owner serviceable parts for this, only Garmin and there authorized repair stations can fix this and get parts.
  • yadayada
    yadayada Nov 12, 2009
    Need feedback from u on this, have the same unit and am familiar with problems, the info is correct, if reset doesn't fix it u need to send it to Garmin for repair.
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
http://www.gpscity.com/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi.html
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
While plugged into car garmin will not display maps
It has gone into "Mass Storage Mode" because it thinks it is connected to a computer. Are you using something other than the Garmin power cord such as a cell phone charger?
Apr 04, 2010 | Garmin nuvi 200W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
Red light on my bb storm when connected to macbook w/ no charge
ok, try this...
Go to (Options -> Memory : then make sure that "Mass Storage Mode Support" and "Media Card Support" is set to "On", and "Auto Enable Mass Storage Mode When Connected" is set to "Prompt".)
Connect to your computer.
Let me know if that works for you. If not we can try a couple other things.
Jul 15, 2009 | RIM BlackBerry Bold Smartphone
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
Getting message of "connecting to mass storage"
did you try changing your connection settings.
Mar 15, 2009 | LG Vu CU920 Cellular Phone
Garmin nuvi 250W GPS Receiver Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
