Question about Canon PowerShot A430 Digital Camera
Canon A430 - horizontal lines
My Canon A430 has developed a problem with Horizontal Lines and bad exposure, much as reported in: "http://www.fixya.com/support/t2811345-horizontal_lines_bad_exposure_in_pics"
However, a UK Canon repair centre has told me there are no recognised faults against the A430 that will be repaired free of charge unless under warranty. They have quoted £89 minimum repair fee (without inspecting the camera).
Yet this fault is repairable free of charge on other models.
Can you advise whom I should contact at Canon to ask for a free repair for what is surely a common design problem?
Thanks.
  • Canon Master
  • 4,738 Answers
Tend to agree with you that it's a common design problem for the A430, but it's a very different issue than CCD failure mentioned in you referenced article.
Please see this Fixya post instead of the one that you mention above. Unfortunately, Canon has yet to officially recognize this A430 specific problem. But if you reference this Fixya post, (include a link), when contacting Canon (if in US, email is CareCenter@cits.canon.com. You'll have to research www.canon.com to find an equivalent UK email contact), who knows you might get lucky
Posted on Nov 12, 2009
Horizontal lines in both my LCD screen and when I download to the computer of my Canon Powershot A430---help I've tried everything?
There is a CCD sensor mechanism problem. Go to a specialist to fix it. Is a very complicated procedure and you cant fix it at home.This is caused by the sand and dust particles and many Canon A 430 cameras have this problem.
May 16, 2010 | Canon PowerShot A430 Digital Camera
Photos come with horizontal stripes and too bright
Hello naushed,
I had the same issue with the white horizontal lines with myCanon Powershot series camera too. When taking pictures, I get the horizontal lines. In daylight, I almost cannot see the pictures because it gives me very bright output. In darker areas, the picture can still be toleratedbut white lines are still there. Although when I am taking a video,the quality is good.
I was able to read that there is one part insidethe camera's mechanism that is faulty. Its a CCD problem. You should bring this to a CanonAuthorized service center and they should replace and fix the faultypart, free of charge. I got my Camera fixed for FREE! I was able to do macro shots again.Trust me and go to canon. What I did is to print this advisory fromcanon itself. And show it to them.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
As part of their advisory:
"Effective immediately, and regardless of warranty status, Canon willrepair, free of charge, the products listed above exhibiting theabove-mentioned malfunction if Canon determines that the malfunction iscaused by the CCD image sensor. Canon will also cover the cost ofshipping and handling in connection with this repair.
Hope this helps.
Nov 18, 2009 | Canon PowerShot A430 Digital Camera
Horizontal lines and bad exposure in pics
Were you able to solve your camera? I got my Camera fixed for FREE! I was able to do macro shots again. Trust me and go to canon. What I did is to print this advisory from canon itself. And show it to them.
Aug 21, 2009 | Canon PowerShot A430 Digital Camera
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Aug 03, 2009 | Canon PowerShot A430 Digital Camera
Horizontal Lines throughout the images
What Canon technician told you that your camera did not have a CCD? You sure that he was from Canon? And also the cost of repair would likely be more than the latest A480. Also note that you can get an A470 for around $70 these days. But no this is likely not CCD failure and is more likely a stuck shutter.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note that the article says to set your camera to 15 second exposure. This is not possible with the A430. Instead set it to manual mode, turn the flash off, and go into a darkened room. Take your picture there. Open the door while the red and yellow lights are flashing. Now the possibility for success with this method is not that great so don't get your hopes up. But it's worth a try before shopping around for a new camera.
May 30, 2009 | Canon PowerShot A430 Digital Camera
That Canon Expert is not giving ur correct info i have done huindreds like this it is 100% CCD Fault and it do have a CCD unit installed either he is not a tech or he is trying something on u , pls dis regard his advice and kindly see below just call canon
CCD FAULT has various SYPTOMS like
Over Exposed Daylight pics indoors ok but extra light is a problem
might be puikish redish or purple tones
Streaks noise or complete Black or Blank pics
dont waste time just call canon
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 28, 2009 | Canon PowerShot A430 Digital Camera
A430 pictures show lines and blurry.
this is a BAD CCD problem thousands are facing dont worry Canon will repair it free of charge even if u are out of warranty and not on list , just call or contact CANON in phillipines see this PLS RATE ME FIXYA for help
http://support-asia.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
contact info in philipines
Canon Marketing (Philippines) Inc
Marvin Plaza Building
2153 Don Chino Roces Ave
Makati City, Metro Manila
Philippines
Tel : cb_transparent_l.gifph.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif+632 884 9000cb_transparent_r.gif
Fax : +632 812 0067
Email : info@canon.com.ph
For: Ophthalmic Equipment
I.O.S. Marketing Corporation
647 P. Paterno Street,
Quiapo, Manila 1001,
Philippines
Tel : +02 733 5443
Fax : +02 733 3767
Email : ios@info.com.ph
Apr 07, 2009 | Canon PowerShot A430 Digital Camera
Taking photos
I have the same problem too with my a430, when i shoot outdoor, it's like over exposed, more of a white, but it's good indoor shooting aside for some horizontal lines. i already reset all the settings, still nothing changed
Mar 03, 2008 | Canon PowerShot A430 Digital Camera
PICTURES FROM CANON A430 POWERSHOOT APPEARS BLURRED AND HAVE HORIZONTAL LINES
Yjis is a component fault.
Contact Canon you may qualify for a free replacement.
Dec 21, 2007 | Canon PowerShot A430 Digital Camera
Taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 Digital Camera Logo
455 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
