Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Have a bizhub C353 conected to a network. Using a
Have a bizhub C353 conected to a network. Using a Windows domain. trying to scan to a network folder..keep geing login failure. Have tested user accountpassword on another MFD (Canon) to the required destination and all ok, but cannot make C353 do this. ANy clues as to why I get the login error
Have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
Posted on Feb 15, 2010
Konica Minolta Bizhub C353 Has not lights on the network card
make sure the new outlet has power coming out of it, It may be connected to a switch or the breaker may be turned off.
Oct 29, 2014 | Konica Minolta Bizhub C353 Color Copier...
We have a KM bizhub 250, and we upgraded our server to a SBS 2008 Server. Now our scanning is not working. What could be the problem?
If this server is also a domain controler that is usually caused by the following setting:
Microsoft Network Server: Digitally Sign Communications (Always), The default setting for domain controllers is enabled, for others is not configured or disabled. This usually causes problems when acessing the share from devices are not cable of Digitally Sign Communications, like some multifunctionals/scanners or linux machines. This does not happen on all machines since some are capable of Digitally Sign Communications. Usually older machines have this issue.
So, try to disable this setting on the server, on the Domain controller security policy and Default Domain Policy.
Administrative Tools
Local Policies
Security options
Microsoft Network Server: Digitally signed communication (always) -> should be changed to DISABLE
Execute Gpupdate /force or reboot the server to apply the policy change
You will not be able to change this setting trough gpedit , local computer policy since it is overrided by the Domain security policy.
On server 2008 one way to get there is the following:
Server Manager
Features
Group Policy Manager
Forest: ...
Computer configuration
Policies
Windows Settings
Security Settings
Local Policies
Security Options
- Define This Policy
- Disabled
Execute Gpupdate /force or reboot to apply policy
Trough gpedit you will be able to see the option but not change it, so I suggest that after the change you cannot scan to the folder check trough gpedit if it is disabled.
If it is not disabled, disable it at the top of the hierarchy. Something may be overriding the setting.
If it still does not work try the following, togheter with the previous setting
Domain member: Digitally encrypt or sign secure channel data (always) -> disabled
Dont forget to execute Gpupdate /force or reboot to apply policy each time you change something.
Also
are you scanning to the server using \\server_ip_address\shared_folder or \\server_name\shared_folder?
Just wondering about name resolution.
Is the domain field configured in the machine? if not you might have to specify the user for authentication like for example: user@domain.local
Dec 23, 2010 | Konica Minolta bizhub C250 All-In-One...
Hi, I just took over a BizHub 350. Whenever I try to scan to a new email address, it doesn't go through and I get the error message "EA3226". Whenever I try to scan and email to an existing email...
The scan-to-email may have been set up originally to utilize the old email server, using the old domain as the conduit for sending the scans through your network.
You may have to load the driver onto the new email server, or the main network server itself (which would then allow you to scan to emails with any destination as it is using the networks connectivity to deliver the emails, not the email server).
Then you can set up as many new user accounts as you want.
Jun 25, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
Jun 04, 2009 | Konica Minolta Office Equipment & Supplies
Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
Mar 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can't Scan anything on a BizHub C550 to 5 pcs on the same network
Be sure that your Domain name is in the network settings on the printer. This can be done on the printer itself or opening a web browser. Put the IP address in the address bar of the browser, this will conect you to the machine. Log off the public domain that come up and log on the administrator area. Enter the password 1 2 3 4 5 6 7 8, unless it has been changed. There you will be able to set all of the network functions. The machine need this information in order to direct the scans to the correct place.
Jan 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
1,695 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
