Question about HP vs15 15"LCD Flat Panel Monitor
How the unlock osd
When use the volume buttons error shown that "OSD LOCKOUT" SO HOW TO UNLOCK THE OSD LOCK
OSD Lockout in HP Monitors First restart the Computer. Then hold down the menu button for 30 seconds, the main menu appears, then exist the main menu, then remove power cable of the monitor, then hold down the power on button of the Monitor for 30 seconds, then plug the power cable to the monitor. The OSD Lockout problem set rights.
Posted on Dec 03, 2009
Osd lock not open
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Most of these lockout problems are fixed by depressing the menu button on the monitor for about 15 seconds and then releasing it.
Apr 04, 2015 | Acer Computers & Internet
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
What does osd lockout mean and how do i get the box off my computer
Lockouts occur when the software driving the OSD encounters a problem or conflict--akin to your PC's operating system freezing.
Follow this link for more info: http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Basically you have Four options to solve an OSD lockout.
Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Good luck and thanks for using FixYa.
Feb 22, 2011 | HP w1907 LCD Monitor
Starting the PC have got error on HP 1730 Monitor error message, OSD Lock out. Can you please tell me how to solve this issue?
How to Unlock an "OSD Lockout" Problem
smilie-tag.png monitor, osd lockout folder-category.pngPosted in Fixes ' Comments (32)
osdlockout.jpg This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix Two: Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three: Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four: The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you know of any other fixes feel free to contact me. Good luck!
Having other problems with your computer? Simply scan your computer for free to identify problem areas.
Techbelkin please rate me
Nov 02, 2010 | HP 1730 LCD Monitor
I have a hp monitor with the number hpf2105 on it
Please see my profile for instruction, or try below, you should also download user manual from HP:
? OSD Lock —The OSD can be enabled or disabled by
pressing and holding the Menu button on the front panel for
10 seconds. If the OSD is locked, the warning message
“SD Lock”displays for 10 seconds.
?If the OSD is locked, press and hold the Menu button for
10 seconds to unlock the OSD.
?If the OSD is unlocked, press and hold the Menu button
for 10 seconds to lock the OSD.
May work the same on other HP model also.
User manual: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
If you want to see the inside of your monitor, look here:
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | HP f2105 21" LCD Monitor
What to do to unblock osd lockout
You can download user manual here: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
See Page 54:
? OSD Lock — The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message "OSD Lock" displays for 10 seconds. ?If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD. ?If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Please leave good rating, thanks.
Mar 31, 2010 | HP vs15 15"LCD Flat Panel Monitor
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
Osd lockout--can not control monitor
if u hold the menu button for 10 seconds it will be unlocked.
Sep 19, 2008 | Computers & Internet
OSD Lock Problem
I have a hanns g 22" widepanel , I had the same problem with lockout. I had my monitor disc and looked on it, or in a manual if you still have it. Here is the combination I had to press and it worked. I pressed the arrow buttons and the menu button all together a few times and it unlocked. Try that!
Function Key Lock:
Press the <「Volume -」, >「Volume +」and the 「Menu」buttons simultaneously to
enable the Function Key Lock. When the Function Key Lock is enabled, only the Power
button is active. Press the <「Volume -」, >「Volume +」and the 「Menu」buttons
simultaneously again to unlock the function keys.
Aug 03, 2008 | Hannspree HW191D LCD Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
2,236 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
