Question about Panasonic KX-P1150 Matrix Printer
Printer offline mode
I am using Windows Xp with KXP 1150 Panasonic printer. I can't make printer ONLINE at printer properties dialog box. The printer works with some other PC.
    Genius:
  • 2,785 Answers
Plz try by with new cable, if the problem is not solved then check your port
Posted on Nov 12, 2009
How to adjust resolution in hp laserjetM1212nf mfp
Optimize and improve image quality
Change print density
You can change the print density setting by from the product Properties dialog box.
1. Windows XP, Windows Server 2008, and Windows Server 2003 (using the default Start menu
view): Click Start, and then click Printers and Faxes.
-or-
Windows XP, Windows Server 2008, and Windows Server 2003 (using the Classic Start menu
view): Click Start, and then click Printers.
-or-
Windows Vista: Click Start, click Control Panel, and then in the category for Hardware and
Sound click Printer.
-or-
Windows 7: Click Start, and then click Devices and Printers.
2. In the list of printers, right-click the name of this product, and then click the Properties menu item
to open the product Properties dialog box.
3. Click the Device settings tab, and then move the Print Density slider to the desired setting.
4. Click the Apply button to accept the setting, and then click the OK button to close the dialog box.
Manage and configure printer drivers
The product uses the paper-type setting to establish many internal settings that affect print quality.
Always use the correct paper-type setting in the printer driver. Also make sure that the other settings
on the Paper/Quality tab in the printer driver are correct.
Aug 27, 2014 | HP LaserJet Pro M1212nf MFP -...
Receiving consistence "printer offline" message. Printer will not print although the printer is on and is properly connected. Have checked it with the pc and the laptop. The printer is fine. Is there...
Go to your Control Panel from the Start Menu. If your OS is Windows XP Click on Printers and other Hardware. Right click on your Canon Printer you are using .Scroll down to Properties. Click on Properties . It should give you the option to put the Printer in question "Printer Online". Click Printer Online. That should remove the option from Offline to Online .Then try to print from your Printer.
Jul 31, 2010 | Canon PIXMA iP1600 Printer
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
I M LOOKING FOR FREE DRIVERS OF PANASONIC PRINTER MODEL NO.KXP-1150
for xp and vista you don't need the driver
xp and vista will automatically install the printer
Jul 09, 2009 | Panasonic Office Equipment & Supplies
Cannot print to network printer
Is this printer installed on a server and shared over a network? Or is it installed independently on each workstation?
If it's on a server, printing could be "paused", or set to "use offline" Go to the "printers and Faxes" dialog box, and 'right click" on the printer icon, is there an option to either "resume printing", or "use printer ON line"? If so, select this option.
If it's not on a server then it would be extremely unlikely that this condition would happen on all workstations
Other than that make sure that the Subnet mask is set correctly on the printer.
If that doesn't work....it's probably time to try re-installing the driver.
May 13, 2009 | Kyocera Copystar CS-1820 Black and White...
Printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Apr 04, 2009 | Zebra 110Xi III Plus Thermal Printer
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother 845cw printer is offline -
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
Feb 29, 2008 | Brother MFC-845CW multi-function...
Panasonic KX-P1150 Matrix Printer Logo
295 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
