Question about HP Pavilion dv6000z Notebook
My HP DV6000 was stuck on 5% then I followed he advice of others on this website and removed the battery it then charged up to 28% and stopped. So I tried it again and it went up to 29% and stopped, so I uninstalled Microsoft ACPI and reintsalled it and it charged up to 30% and stopped. So now its stuck at 30%, any suggesstions?
  • jamie_haumah Nov 14, 2009
    Sorry it was that the battery wasn't charging properly, it would start but only for a few seconds and then stop.
  • Richard  Scott
    Richard Scott May 11, 2010
    what was the oringal problem Is the battery playing up?
  • HP Master
  • 32,281 Answers
If the laptop battery is 3 - 5 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time until they won't charge up at all.
Posted on Nov 12, 2009
Testimonial: "great, thnx 4 yr help"
  • Chris Hingee
    Chris Hingee Nov 14, 2009
    The fault could still be a faulty, especially if the battery is old.
    If you can put your battery into another HP DV6000 and charge it up and if the battery charges to full capacity then the fault is the charging circuit in your HP laptop.
    The charging circuit is part of the motherboard and would be difficult to fix, the cost of the repair most likely will be expensive, I suggest you get a quote before you decide to go ahead with the repair.
  • 77 Answers
Is your battery newly purchased?
If NEW battery:
you need to discharge it fully and charge it again. you need to repeat the process 3x. you should see some changes in the percentage
if battery is OLD
then you might need to change to a new one.
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
Hey, i have a HP Pavilion dv6000 and since yesterday if i unplug the power cord it shuts off. i know that means the battery is not working but im not sure as to why. the battery meter is telling me that it...
Hi, when using the (AC Power Adapter), it is important that once the (Battery) is fully charge; to do one or the other. Stop! using the AC power, shutdown the computer, and unplug the AC power; use the battery (only), or remove the battery, and use (only) the AC power. Note: Using both power sources this can cause damage to the battery, by over charging, and possibly over heating the computer. Thanks paul7of9
Jan 05, 2010 | HP Pavilion dv6000z Notebook
HP DV6000 Won't Charge
The charging process is suspended temporarily because the battery has overheated. My brand new DV5 (3 weeks old) does the same, because it's really hot here.
Turn the laptop off and the battery should charge. Also, when you do not need the battery and are running off the mains, remove it from the laptop. Keeping a battery at 100% wears it 4 times faster than doing regular charge/discharge cycles.
Jul 02, 2009 | HP Pavilion dv6000t Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
DV6000 GT375EA#ABU Only powers on from its battery
I have had the same issues with my HP dv6208 laptop. I ended up sending my laptop in at their expense to get it fixed. My suggestion to you is to go to the HP support website and chat or call them. The dv6000 series laptops had several issues with the MB and wireless card. they should replace the failed part for free even if the laptop is past its regular warranty. HP extended the warranties on several of these laptops in this product line because of the failures. You have to tell them the serial number, product number and model and they tell you wether it is covered or not. Otherwise I am pretty sure you are looking at a new motherboard for your laptop. Hope this helps...
May 12, 2009 | Computers & Internet
Battery is not charging
From HP website- worked immediately for me.
This document pertains to HP Notebook PCs with Windows Vista. Understanding battery charging issues If the notebook battery is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues. Uninstalling and reinstalling power management software in Windows Vista In order to correct problems with the battery's power management software, follow the steps below.
  1. Click Start and type device in the search field, then select Device Manager .
  2. Expand the Batteries category.
  3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall . WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
  4. On the Device Manager taskbar, click Scan for hardware changes c01176420.gif . Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging.
Oct 19, 2006 | HP Pavilion zd8000 Notebook
HP Pavilion dv6000z Notebook Logo
254 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
