Question about Nokia E51 Cellular Phone
Phone continually hangs when i press the menu button. i have to turn the phone off and back on to get it to work. what can i do?
HOW DO YOU RESET A HUAWEI WINDOES PHONE MODLE H883G
turn off your phone or if it is in hanged stage take off the battery. put on the battery press volume down button and end button (usually used to come back to the home screen) and load the boot menu and you can use volume up and down button to select the desired options you want and reboot.
May 16, 2015 | Huawei Cell Phones
Connect Phone and I/F module , "incoming call" displayed couldn't hang up.
try recycing the power on that...hook up the two modules with power off, then turn power on..it is possible that connecting them while on, would glitch the system
Oct 22, 2008 | Polycom SoundStation2 Audio Conference
Tip
Siemens MODELS CODES & DESCRIPTIONS
*#0003*(secret code 8 digits)# All Siemens Phones: Service Provider Unlock
Siemens S25/C25
SP unlock *#0003*(secret code 8 digits)#
Show IMEI code: * # 06 #
Resets language to automatic selection : * # 0000 # then Green button
Pin Out
Data Cable schematics
Phone's connector pin-out:
1- GND
2- SB
3- POWER
4- NC
5- TX
6- RX
7- CLOCK
8- DATA
9- GND MIC
10- HF MIC
11- AUDIO
12- GND AUDIO
Siemens S1/S3/S3 Com
To view the software date and else with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey.
To view some other stuff with S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey twice.
To view the software date with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM installed menu 98 and left softkey twice.
ACTIVATE MONITOR MODE
Siemens S1/S3
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, Hang-Up Button (Red Handset key)
Siemens S3 COM/S4
Menu, 9 (Phone Options), 7 (Phone Status - 8 on Some), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Note: Now Monitor should appear at the bottom of the Network Options menu.
MONITOR MODE
Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes
Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals.
Test Mode Indicators: (* = only available when call in progress )
CH Channel Number
RX Signal Strength (dB)
N NCC (Colour Code)
B BCC (Colour Code)
CI Cell ID (in Hex)
C1+ How long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01) and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
POWER table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S1/S3
Here's a trick to play Tetris, also known as Klotz on a Siemens S1.
Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps.
1: Choose F 9 (function settings)
2: Choose send own number and push the right button for choose.
3: Push 9
USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4.
[I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparently someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all.]
Siemens S3 Comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
Hang-Up Button. (Red Handset key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE
Siemens S4/S4 Power
In phonebook under "Own Phone No." enter +12022243121 (which is the number to the White House) and you'll get a greeting from the people who programmed the phone.
MONITOR MODE
The Siemens S4 series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Now "Monitor" should appear at the bottom of the Network Options menu.
CH Channel Number
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
RXAM Reeceive signal strength cut-off point
PL* Power Level
Power Table
Siemens S6/S10
In Phonebook, store as your own number: +12022243121
Then you get the sun and two palms in the display, also a greeting message of the "MMI-team".
It has been said that the phone number is the number of the Capitol building in Washington, DC (but not sure).
Siemens S15 Secret Menu's
Press * -> # -> 7 -> 4 -> 3 -> 6 -> 3 -> 6 -> 7 -> * -> 8 -> 3 ->
7 -> 8 -> # ,press clear key to clear screen and return to
stand-by mode
press Menu, it will show additional menu
Menu 3.3.4 Band selection,
Menu 3.3.4.1 Automatic band selection,
Menu 3.3.4.2 select GSM 900 only,
Menu 3.3.4.3 select GSM 1800 only,
Menu 10 Engineering,
Menu 10.1 MS info,
Menu 10.2 software detail,
Menu 10.2.1 software version,
Menu 10.2.2 EEPROM version,
Menu 10.3 Test/production details
Menu 10.3.1 Hardware deta
Menu 10.3.2 production deta
Menu 10.3.3 Service deta
Menu 10.3.4 Mechanical deta
Menu 10.1.1 MS info on, then on the screen show these, for example:
FCN RXL C1 C2
642 011+11+91 -> PAGE 1
CID DSC CB
11211 045 000 -> PAGE 2
BCC NCC TN
000 002 00 -> PAGE 3
RXf RXs RQf RQs
00 00 00 00 -> PAGE 4
ATa APa Hn Hf
001 000 05 00 -> PAGE 5
DTU DTD HP CI
+ ? - - -> PAGE 6
MM CC RR
IdNS Nul Idl -> PAGE 7
on Aug 30, 2009 | Nokia 9500 Communicator
My Kyocera Event 3g smartphone keeps turning off and on by itself over and over again every time i take the battery out and put it back in i don't even have to press the power button because it turns on by...
Sound like you have to restore the phone and if still persist..phone replacement if battery is good.If you have an SD card in phone remove it please. Make sure your picture and contacts are backed up to SD card. This will take phone back like new.
    • Turn off the phone.
    • 2 Hold down the "Volume," "Power" and "Home" buttons at the same time. Continue holding the buttons until the 3-D Android logo and a menu of system options appears on the screen, and then release the buttons.
    • 3 Press the "Volume" button to scroll through the menu options and highlight "Wipe Data/Factory Reset." Press the "Power" button to select the option.
    • 4 Use the Volume button again to highlight "Yes, Delete All User Data," and then press the "Power" button. The Event deletes all your personal data and settings from the phone and then returns to the first menu.
    • 5 Highlight "Reboot System Now," and then press the "Power" button to restart the phone. After several minutes, the Event starts up and opens the main screen, giving you the option to set up the phone just as if it were brand new.
Feb 10, 2015 | Kyocera Cell Phones
Reset password
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7.
Source: http://www.hard-reset.org/factory-default/how-to-easy-master-format-nokia-e7-with-safe-hard-reset/
Jan 15, 2014 | Nokia E7 (16 GB) Smartphone
My nokia 6120 is in offline mode. Its made by Korea. When i connect then option is do u want to continue with offline then yes otherwise no. is i press no then cell is hanged but when i press yes then just...
hi,
try this; select yes, when the phone is completely on, press the off button once and then select general. Or open your phone's profile menu and select general. That should solve it
pls rate this
Jul 06, 2011 | Nokia 6120 classic Cellular Phone
H,i I tried to give a hard reset my phone but pressing the key recovery and has a symbol on the screen, now does not respond, how long should I wait or should it be immediately?
Did you press the MENU.
Follow the following steps:
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, andthen re-install it. After re-installing the battery, turn on the phone.
Mar 17, 2011 | HTC Hero Smartphone
I want to configure... email settings in samsung mobile
Hello
1. Locate information concerning your particular email service's incoming POP3/IMAP and outgoing SMTP server addresses. Refer to the resources section below for a list of server settings that pertains to many common e-mail providers.
2. Turn on your mobile phone and wait for the standby screen to appear. Touch the "Menu" button on your screen and select "Messages" from the menu, press "Select" to continue.
3. Go to the "Settings" menu and press "Select," choose the "Email" option. Select the "Email setup wizard," press the "Select" button and hit "Yes" to continue.
4. Choose an email account type you wish to configure, press "Next," choose the "Account" option, press "Name" and use your keypad to label your new email account.
5. Press the "Next" button to continue with the email setup. Enter your email address and password, press "OK" to continue.
6. Enter the incoming POP3/IMAP information pertaining to your particular email service and press "OK" to continue. Select the "Outgoing Server (SMTP" menu item) and enter in the appropriate SMTP address for your email provider and press "OK" to continue.
7. Hit the "Select" touch screen button and wait for the "You have configured this email account successfully" dialog to appear.
GOODLUCK
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
Hanging
software problem..contact service techn
Jun 30, 2009 | Nokia 3120 Cellular Phone
Mp3 won't turn off and the screen doesn't work
My Sansa wouldn't turn off and I got it to do so by pressing the center button while holding the main menu button down. But then once I did, it wouldn't boot back up.
Mar 24, 2007 | SanDisk Sansa e200 MP3 Player
Nokia E51 Cellular Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
